[ 8 posts ] |
Free The Tone String Slinger
Jyda
Joined: 10 Jan 2004, 12:09 Posts: 1927 Location: Stockholm
Snake oil?
- New HTS (Holistic Tonal Solution) Circuit: this new circuitry delivers excellent, resonant buffered tone with minimal noise. Perfect in any signal chain! - Free The Tone Custom Knobs: custom turned brass knobs to reduce vibrations. Size and shape carefully calculated to minimise unwanted noise and movement, while adding to the tone of the pedal itself. - Sound Casing Design: every aspect of a pedal's design can affect its sound. The dimensions and weight of the String Slinger have been optimised to deliver the best sound! - Unique IC Tone Plate: this metal plate for damping and shielding covers the top of an IC chip to make the most of the characteristics of the IC and to prevent noise contamination to the utmost. - Passive Tone Circuit: a passive tone circuit minimizes the phase shift in guitar signals.
_________________ The easiest thing is to be an artist because there is no diploma for it. Come and be a doctor, a philosopher, an atomic physicist, if you can. Artists! I don't like artists. - Ara Güler
| 26 May 2021, 10:05 |
clapton71
Joined: 15 Mar 2008, 18:36 Posts: 4460 Location: Örsundsbro
 Re: Free The Tone String Slinger
Garvade högt när jag läste pitchen men faktum är att den låter alldeles förträffligt! En pedal som gör att andra pedaler låter bättre, skulle man kunna säga. Som en extra kanal på stärken, dock inga mängder gain, i alla fall inte med single coils. Jag hade min sist bland drives, som en alltid på pedal. Idag kör jag en loopswitcher och en Archer istället.
Matte
_________________ the older I get, the better I was
| 26 May 2021, 10:44 |
Goran
Joined: 03 Jan 2008, 12:21 Posts: 7818 Location: Malmö
Låter rätt vansinnigt, vem hör ev missljud från t ex en ratt, vid fullt spjäll....
| 26 May 2021, 11:00 |
Lynxtrap
Goran wrote: Låter rätt vansinnigt, vem hör ev missljud från t ex en ratt, vid fullt spjäll.... Eric Johnson uppges höra skillnad på vilket märke av jeans personen som monterade ratten bar.
| 26 May 2021, 16:40 |
zoork_1
He he, du har lite humor du...
| 26 May 2021, 21:11 |
Lynxtrap
Pedalen ska väl efterlikna en Dumble Steel String Singer, och det funderades väl i liknande banor när förlagan kom till antar jag..
| 27 May 2021, 10:00 |
Robert
Joined: 19 Dec 2008, 23:22 Posts: 1891 Location: Göteborg
Goran wrote: Låter rätt vansinnigt, vem hör ev missljud från t ex en ratt, vid fullt spjäll.... För att inte tala om hur storleken på boxen påverkar ljudet  Ja, det är 100% bullshit buzz words. Nästan så att jag tror att det extremt väl dold ironi. Sen kan den ju fortfarande låta bra, och har man 4 lax som man känner bränner hål i plånboken, så varför inte?
| 27 May 2021, 11:45 |
lpstd
Joined: 29 Apr 2010, 13:47 Posts: 2780 Location: Sthlm
Jag är helt övertygad om att ju mer man börjar uppfinna nya problem i sin strävan efter det perfekta ljudet, desto mer missnöjd blir man. Men missnöje är ju också ett nöje.
| 27 May 2021, 13:07 |
[ 8 posts ] |
Users browsing this forum: No registered users and 59 guests |
