View unanswered posts | View active topics It is currently 15 Nov 2026, 04:18
Minihumbuckers The Creamery UK SÅLDA
Post Minihumbuckers The Creamery UK SÅLDA
Ett set minihumbuckers "Fat" från The Creamery i England. Kompletta med fjädrar, skruvar. Kåporna är krom. Humbuckerramarna, standard humbucker, (s k adapterramar) följer med på köpet.
SÅLT
26 Jan 2020, 12:58
Post Re: Minihumbuckers The Creamery UK
The Creamery: https://www.creamery-pickups.co.uk/cust ... amery.html
26 Jan 2020, 13:52
Bymp (lite franska där...) :D
07 Feb 2020, 08:19
På en överväldigande förfrågan har jag mätt mickarna. De mäter 9,57K respektive 11,20K.
De är custom och jag hittade precis Creamerys (Jamie) svar på mitt mail:
"2016-01-16 18:20 GMT+01:00 Jaime @ Creamery Pickups <jaime@creamery-pickups.co.uk>:
Hi Ake, I can make you a custom set with more in the mid-range - perhaps a combination of strong Alnico 5 magnets and thinner 43awg coil wire, that way you’d have a hotter output with a fatter, fuller, more mid-range sound, especially in the bridge position. I can make them calibrated for good balance through the positions.
Hope this helps Ake but do let me know what you think and we can work on the best design for you.
And thanks for getting in touch.
Jaime"
15 Feb 2020, 20:14
