View unanswered posts | View active topics It is currently 24 Nov 2026, 11:13
Jfret by tilman preamp utan strul
Post Jfret by tilman preamp utan strul
snodde från nätet .
Minimalt me komponenter som kan förvränga signalen.
Billig enkelt alla kan bygga
I've been performing experiments with guitar preamps and on-board electronics since, oh, the Nixon adminstration or thereabouts. Sometime around 1990 I designed this preamp circuit, and have been using it mostly unchanged ever since. In 1992 I posted a schematic of the preamp to one of the Usenet groups and the circuit became somewhat popular.
The goals of the preamp are:
Sounds great. Of course.
Discrete FET (Field Effect Transistor) design. Discrete because I don't like the sound of opamps, and FETs because the devices operate in a manner somewhat analogous to vacuum tubes.
Runs off a 9v battery. In practice a decaying 9V battery, possibly as low as 8.0 volts.
Very high (3.0 Mohm) input impedance. 1.0 Mohm is the minimal acceptable input impedance for a guitar device.
Medium (6.0 Kohm) output impedance. There's no need for an especially low output impedance as we're only using the preamp to counter the effects of cable capactance and loading.
3 dB gain. You don't need much gain, and given the guitar signal level and the 9v supply voltage, there isn't room for much gain.
Low noise.
Graceful overload. Overload happens; the circuit should clip gracefully and recover gracefully.
The preamp can also be phantom powered and mounted in a phone plug. See my article "An FET Preamp Cable".
Ska vi bli några st så vi får ihop till ets å framkallning 100krst
Det är absolut en av de största,som tillverkat den för egetbruk så inga pengar till han.
Jag lödde in en Blade preamp åkte ur lika snabbt men idén gillas.
Schematic
03 Nov 2016, 04:40
Post Re: Jfret by tilman preamp utan strul
ehhh... schema?
"The Tone is in your pants"
http://kuhnamps.com
04 Nov 2016, 12:15
http://www.till.com/articles/GuitarPreamp/
06 Nov 2016, 02:03
Sök på nätet efter tilman
bygg den som boost eller od
Sök på youtube.
06 Nov 2016, 02:11
Users browsing this forum: Google [Bot] and 68 guests
