Här är listan med 'features' som presenterades 2006
Below listed are the features of the new Custom Shop VOS guitars:
• Holly Headstock Veneer (as opposed to a wood composite fiber)
• Silk Screened “Les Paul” signature on headstock (as opposed to a decal)
• Correctly tapered and shaped headstock
• Push in bushing tuners are in a straight line (as opposed to following the headstock edge)
• Tuning Peg bushings changed to feature the little “knurl” on top as found on the original Klusons
• 3/8 inch back-edge radius
• Historic Spec Truss Rod Cover
• Historically accurate thin 0.04 inch thick Fingerboard binding with “Rolled” edges to give a more comfortable playing area
• Vintage profile fret wire with computerized “perfect” nut cutting
• Tortoise Dot Markers on the side binding of the neck
• Historically accurate Trapezoid Inlay shape with sharp points and authentic “swirl” patterns
• Accurate Truss Rod Route with rounded end for easier adjustment
• Long Thick Neck Tenon extends to a point under the neck pickup cavity (tight fit allows both neck and body to resonate as one)
• Historically Accurate Carved tops with a flat level center plane which allows bridge and tailpiece to be mounted closer to the body for increased resonance
• Correct height of the binding in the cutaway exposing a slim piece of maple top (as on originals)
• Solid one piece NON-weight relieved mahogany backs (not bookmatched)
• Thinner Nitro-cellulose lacquer finish which is applied, sanded and buffed the way it used to be, leaving a gently aged patina.
• Period correct stain and filler
• Strict weight limits on mahogany backs
• Select maple tops are AA (vs. AAA) which are visually closer to the originals
• Faded Sunburst finishes reflect natural aging colors (e.g. Washed Cherry, Faded Tobacco, Iced Tea.)
• Accurately sized back control pocket route
• Historically accurate ½ inch wire channel from toggle switch to control pocket
• 5/8 inch heel with accurate heel shape
• Correct distance between neck & bridge pickups
• Historically accurate thin switchwasher and jackplate that better conforms to the shape of the body
• Silk-screened “Rhythm and Treble on the switchwasher with Vintage Amber colored Switch Tip
• Historically accurate bridge, tailpiece and control holes
• Historically accurate reproductions of the original PAF Humbuckers (Burstbucker 1 & Burstbucker 2) using original wire manufacturer with mismatched windings and “Patent Applied For” stickers
• CTS Pots (made with a solid carbon glide as opposed to a thin foil layer on fiberboard)
• Bumblebee Capacitors (original foil-in bakelite as opposed to paper)
• Vintage style ABR-1 bridge is screwed directly into the top as were the originals
• Historic Spec Lightweight Aluminum Tailpiece (which rings with string vibrations rather than the heavier which absorbs them)
• Computerized set-up ensures superb playability on each Custom VOS
• Volume & Tone Indicators (where applicable)
• Period correct control knobs (e.g. gold bell or reflector)
• All hardware is chemically aged to replicate decades of natural oxidation.
• Custom Shop Reissue Lifton Case
• Certificate of Authenticity, Custom Care Kit, Hang Tags
