View unanswered posts | View active topics It is currently 27 Nov 2026, 20:33
Anybody build pedal boards, or cable them?
Post Anybody build pedal boards, or cable them?
Looking for a tech savy guru who either builds or modifies pedal boards, and/or makes custom high end soldered patch cables for them.
Within the Gothenburg area, or with a 45 minute drive from Gothenburg if possible. You ca PM me info and rates.
Thanks!
28 Feb 2015, 14:17
