[ 15 posts ] |
Boss Noise suppressor NS-2
J Alkarp
Boss Noise suppressor NS-2 säljes. Byten är intressanta.
| 21 Jun 2006, 12:35 |
Rock_N_Ron
Oki-doky, hur fungerar en så´n då <img src=icon_smile_blush.gif border=0 align=middle>
Som en Noice Gate att sätta sist i signalkedjan för att ta bort pedal- & mickbrum, eller?!? Vad händer med "sustainen" om man vil hänga på en ton? Feedback man faktiskt vill ha? (har aldrig använt noice gate förutom i en gammal sunkig multi-effekt & den var värdelös. Den klippte av om man hängde på en ton precis när det gôttiga rundgången började komma. Därav dessa "dumma" frågor...)
Pris? Ev. byte mot en Boss SD-1 (sent -80-tal - cool!) om bytesvärdet känns OK?
= = = = = KEEP ON ROCKIN´ IN THE FREE WORLD = = = = =
| 21 Jun 2006, 15:22 |
Carl_T
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Oki-doky, hur fungerar en så´n då <img src=icon_smile_blush.gif border=0 align=middle> = = = = = KEEP ON ROCKIN´ IN THE FREE WORLD = = = = = <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> <img src="http://www.bossarea.com/images/NS2.jpg" border=0> The NS-2 can be connected in two different ways. You can connect the NS-2 last in your chain of effects. The output of the previous pedal goes to the NS-2 input jack. Wire the Output jack of the NS-2 to your amp. The NS-2 can also be wired like an effects loop, which allows you to kill your entire signal chain just by stomping on the NS-2. Take the Send output of the NS-2 into your first pedal. Take the output of your last pedal and wire it to the Return jack of the NS-2. The NS-2 uses an intelligent circuit to differentiate between the sound of the guitar and noise. The NF-1 simply cut all sound when it became weaker than a threshold value. The NS-2 attempts to let the sound of the guitar through while removing the noise. Boss Advertisement text: The NS-2 effectively eliminates signal noise and hum while preserving the tonal characteristics of the original input signal. The natural attack and envelope of the signal itself are unaffected because of BOSS' unique noise detection circuit that precisely separates the guitar sound from noise components. When connected to an AC adaptor, the NS-2 can also supply power to other effects units. Specifications Controls: Threshold, Decay, 2-way Mode Switch Connectors: Input, Output, Return, Send, 9V DC In, 9V DC Out Current Draw: 20 mA (DC 9V) Weight: 400 g (15 oz.) Recommended AC Adaptor: PSA Series Labels Silver - Made In Japan Silver - Made In Taiwan The NS-2 was sold from September 1987 to present. (här hittar man allt om Boss: http://www.bossarea.com) --- Sätt in ett ", tycker jag" efter alla mina meningar för säkerhets skull.
| 21 Jun 2006, 15:51 |
J Alkarp
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>Oki-doky, hur fungerar en så´n då
Pris? Ev. byte mot en Boss SD-1 (sent -80-tal - cool!) om bytesvärdet känns OK? <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Jag har bara använt den med en les paul med en p-90 i, på den gitarr en tog den bort det mesta utav brummet utan att klippa för mycket utav sustainen. Jag har faktist ingen aning om hur mycket en sån här är värd, Din sd-1 vore intressant om det inte vore för att jag har för många dist pedaler, jag är mest ute efter anorlunda gitarr prylar.
| 21 Jun 2006, 16:13 |
Rock_N_Ron
Har en sprillans Boss Tremolo TR-2 oxå som knappt används. Ungefär samma nypris. Hör av dig om den är intressant så kan vi "snacka" om ev. byte. Har inte bestämmt mig själv rikitgt...
Vad hade du tänkt dig för kontaktpris (NS-2:an kostar visst 700 spänn på Börsen ser jag)
| 21 Jun 2006, 21:37 |
J Alkarp
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Har en sprillans Boss Tremolo TR-2 oxå som knappt används. Ungefär samma nypris. Hör av dig om den är intressant så kan vi "snacka" om ev. byte. Har inte bestämmt mig själv rikitgt...
Har du lite mer info om pedalen, jag vill helst ha en talkbox eller någon annat ovanligt som byte.
| 21 Jun 2006, 21:57 |
Carl_T
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Har en sprillans Boss Tremolo TR-2 oxå som knappt används. Ungefär samma nypris. Hör av dig om den är intressant så kan vi "snacka" om ev. byte. Har inte bestämmt mig själv rikitgt... Vad hade du tänkt dig för kontaktpris (NS-2:an kostar visst 700 spänn på Börsen ser jag) = = = = = KEEP ON ROCKIN´ IN THE FREE WORLD = = = = = <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Har du lite mer info om pedalen, jag vill helst ha en talkbox eller någon annat ovanligt som byte. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Uhum.. som sagt: http://www.bossarea.com/ eller i det här fallet: http://www.bossarea.com/loadpage.asp?file=boxes/tr2.xml--- Sätt in ett ", tycker jag" efter alla mina meningar för säkerhets skull.
| 22 Jun 2006, 04:21 |
Rock_N_Ron
Kalle är på hugget...
Ja, en Tremolo är en Tremolo. Köpte den ny hos Thomann för bara ett halvår se´n & kom på att jag kanske inte kommer att använda den så mycket.
Men som sagt; vad vill du ha i cash för din pedal? Är inte säker på att jag vill byta. Pedaler kan man ju inte ha för många av <img src=icon_smile_big.gif border=0 align=middle>
| 22 Jun 2006, 08:11 |
J Alkarp
Den kostar 800 på thomann men dom skriver inget om den där så jag vet inte om den är made in japan eller taiwan, min är gjord i Japan.
| 22 Jun 2006, 13:21 |
Rock_N_Ron
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Den kostar 800 på thomann men dom skriver inget om den där så jag vet inte om den är made in japan eller taiwan, min är gjord i Japan.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Visst, men det är fortfarande inte svar på min fråga: Vad vill du ha för den?
(Den kostar 700 pix på Börsen. Jag köpte min TR-2:a fr. Thomann & upptäckte se´n att Börsen faktiskt va´ blligare <img src=icon_smile_blush.gif border=0 align=middle>)
| 22 Jun 2006, 15:35 |
J Alkarp
Jag vet inte vad jag vill ha för den, vad kan du tänka dig att betala
| 22 Jun 2006, 16:47 |
Carl_T
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Kalle är på hugget... <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Ja jäklar! <img src=icon_smile.gif border=0 align=middle> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Den kostar 800 på thomann men dom skriver inget om den där så jag vet inte om den är made in japan eller taiwan, min är gjord i Japan. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Om du kikar på http://www.bossarea.com så ser du att TR-2:an bara finns från Taiwan (utgående ifrån att de har rätt, vilket de IMO brukar ha) --- Sätt in ett ", tycker jag" efter alla mina meningar för säkerhets skull.
| 22 Jun 2006, 17:46 |
J Alkarp
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Kalle är på hugget... <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Ja jäklar! <img src=icon_smile.gif border=0 align=middle> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Den kostar 800 på thomann men dom skriver inget om den där så jag vet inte om den är made in japan eller taiwan, min är gjord i Japan. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Om du kikar på http://www.bossarea.com så ser du att TR-2:an bara finns från Taiwan (utgående ifrån att de har rätt, vilket de IMO brukar ha) --- Sätt in ett ", tycker jag" efter alla mina meningar för säkerhets skull. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Vad är det för pris skillnad på en pedal från Japan och en ifrån Taiwan
| 22 Jun 2006, 17:49 |
Carl_T
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Kalle är på hugget... <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Ja jäklar! <img src=icon_smile.gif border=0 align=middle> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Den kostar 800 på thomann men dom skriver inget om den där så jag vet inte om den är made in japan eller taiwan, min är gjord i Japan. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Om du kikar på http://www.bossarea.com så ser du att TR-2:an bara finns från Taiwan (utgående ifrån att de har rätt, vilket de IMO brukar ha) --- Sätt in ett ", tycker jag" efter alla mina meningar för säkerhets skull. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Vad är det för pris skillnad på en pedal från Japan och en ifrån Taiwan <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Som sagt, i just fallet med en TR-2 så finns den bara från Taiwan. När det gäller andra pedaler så ska prisskillnaden vara 0kr för det är samma pedal. I vissa specifika fall finns det skillnader i ljudet mellan pedalerna och då kan priserna bli olika. T.ex. med Boss DS-1:an så är det lite snack om olika produktionsår osv. De enda Boss pedalerna där produktionslandet blir intressant är egentligen delaypedalerna, särskilt DD-2 och DD-3:orna. Annars så är det pedal som pedal, alltså helt olikt från gitarrer som vi gärna värderar efter produktionslandet (och det är därifrån jag antar att du fått funderingarna) --- Sätt in ett ", tycker jag" efter alla mina meningar för säkerhets skull.
| 24 Jun 2006, 15:08 |
Rock_N_Ron
Jesper; jag repade lite igår kväll & upptäckta att jag inte är i nå´t större behov av en så´n här pedal.
Lycka till med försäljningen!
EDIT/PS! Såg på det däringa andra gitarrforumet (GMF) att det fanns en köpes annons på en så´n häringa pedal. Kolla där så blir du kanske av med den!
Edited by - Rock_N_Ron on 26 June 2006 10:59:26
| 26 Jun 2006, 08:32 |
[ 15 posts ] |
Users browsing this forum: No registered users and 16 guests |
