View unanswered posts | View active topics It is currently 14 Nov 2026, 15:31
Reply to topic  [ 69 posts ]  Go to page 1, 2, 3  Next
Fender Mustang Special >>> DRAGNING ONSDAG 14/5 18:25 <<<
Post Fender Mustang Special >>> DRAGNING ONSDAG 14/5 18:25 <<<
Lottar ut denna otroligt vackra, oerhört mångsidiga, fantastiskt lättpselade Fender Mustang Special Pawn Shop kulören Candy Apple Red. Byggd i Japan! Med 24" skala och humbuckers som går att splitta på båda coilsen är den här ett jäkligt roligt vapen att ha i arsenalen!
1. pafal
2. Bentooshape
3. storis
4. ant0n
5. Billberg11
6. VIP
7. Cypher
8. Edvin Medvind
9. Daz_j
10. harestorp
11. PistonR
12. spindeln
13. storis
14. Andreas Nyström
15. Krallen
16. Daz_j
17. spindeln
18. pafal
19. Mefiboset4935
20. Voidoid56
21. valvetubes
22. wekta
23. wekta
24. Edvin Medvind
25. Mefiboset4935
26. ChronicTown
27. rocky67
28. harestorp
29. helmik
30. Edvin Medvind
31. valvetubes
32. helmik
33. Ulfern
34. PistonR
35. Voidoid56
Body Material: Alder
Neck Material: Maple
Neck Finish: Urethane
Neck Shape: '60s "C"
Scale Length: 24" (610 mm)
Fingerboard: Rosewood
Fingerboard Radius: 9.5" (241 mm)
Number of Frets: 22
Fret Size: Medium Jumbo
String Nut: Synthetic Bone
Nut Width: 1.650" (42 mm)
Position Inlays: Dot
Truss Rods: Standard
Truss Rod Nut: 3/16" Hex Adjustment
Neck Plate: 4-Bolt
Bridge Pickup: Enforcer™ "Wide Range" Humbucking with Downsized Wide Range Covers
Neck Pickup: Enforcer™ "Wide Range" Humbucking with Downsized Wide Range Covers
Controls: Master Volume, Master Tone; Pickup Toggle Switch; Coil Selector Switch for Each Humbucker
Pickup Switching: 3-Position Toggle: Position 1. Bridge Pickup, Position 2. Middle Pickup, Position 3. Neck Pickup
Pickup Configuration: HH
Special Electronics: Coil Selector Switch for Each Humbucker
Bridge: 6-Saddle Vintage-Style Strat Strings-Through-Body Hardtail
Hardware Finish: Chrome
Tuning Machines: Vintage-Style
Pickguard: 3-Ply Mint Green
24 Apr 2014, 16:15
Post Re: Fender Mustang Special Pawn Shop 3500kr
Finns kvar!
30 Apr 2014, 21:10
Nu får du ju snart gå med på ett byte mot min Peavey T-60... 8)
01 May 2014, 10:32
Hmm... https://www.youtube.com/watch?v=N493CQgQ_Hk :wink:
01 May 2014, 11:47
(Sorry får trådkladd...) Najs Mustang som sagt!
01 May 2014, 12:29
Post Re: Fender Mustang Special >>> LOTTO 110kr/st
LOTTO!!
07 May 2014, 19:11
Jag tar nr 21 och 31 .
07 May 2014, 19:52
jag kan ta 3 och 13, tack.
07 May 2014, 21:17
Jag tar #27 och hoppas på tur(ina).
07 May 2014, 21:30
22 och 23 tack!
07 May 2014, 21:41
4
07 May 2014, 21:55
Sätt mig på nr 10 om den är kvar.
07 May 2014, 22:07
1
07 May 2014, 22:09
Förresten: Antar att du som i alla andra "lottos" på forumet ordnar med fri frakt?
07 May 2014, 22:10
Listan uppdaterad!
Yes box!
07 May 2014, 23:53
No 6 tack :-)
08 May 2014, 05:26
Nr 16 tack
08 May 2014, 05:51
Tar nr 9 också!
08 May 2014, 06:38
Tar 33!
http://digressionassassins.bandcamp.com
08 May 2014, 09:13
Den här är jag nyfiken på - nummer 5 till mig tack
08 May 2014, 09:25
Nr. 2 tack!
08 May 2014, 11:49
Nr 7 om det är ledigt
08 May 2014, 13:16
Nr: 15 tack !
08 May 2014, 13:18
7, 24 och 30 tack!
/J
edvin.medvind(a)gmail.com
08 May 2014, 13:20
jag kan ta 11 & 34, tack!
08 May 2014, 13:30
Edvin Medvind wrote:
7, 24 och 30 tack!
/J
7 är upptagen, någon annan siffra som lockar?
08 May 2014, 13:38
8 då istället
08 May 2014, 13:44
14 tack
08 May 2014, 14:20
Bentooshape wrote:
Nr. 2 tack!
08 May 2014, 15:48
26 tack - får ju testa att få guran på detta sätt istället... :-)
08 May 2014, 15:55
Users browsing this forum: Google [Bot] and 28 guests
