View unanswered posts | View active topics It is currently 29 Nov 2026, 05:36
Reply to topic  [ 19 posts ]
Guitar audio till midi polyfoniskt utan extra mickar !
Post Guitar audio till midi polyfoniskt utan extra mickar !
Lysande produkt , testa
http://jamorigin.com/products/midi-guitar/
What is MIDI Guitar?
MIDI Guitar is a revolutionary piece of software that converts your guitars analog signal into MIDI, making it possible to use your standard guitar as a MIDI controller/ MIDI keyboard. Play your favorite software synthesizers/samplers with your guitar. MIDI Guitar is the worlds first low latency, polyphonic software solution, allowing you to play both chords and single notes with instant audio feedback.
Traditionally guitarists have had to seek out expensive and inconvenient hardware to be able to use a guitar as a MIDI controller. MIDI Guitar removes the need for any kind of specialized hardware beside a standard guitar interface to connect your guitar to your computer. Just connect your guitar and let MIDI Guitar do the rest.
MIDI Guitar comes in two variants, a standalone application that supports hosting of VST/Audio instruments and effects that be used without any additional software installed and a VST/AudioUnit variant that can be used in with your favorite Digital Audio Workstation (DAW) software.
Join many guitarists around the world and try MIDI Guitar today. Download the free trial where you can try all the features included in the full version and use it unlimited with the built-in samplers and synthesizers. When using the trial version with MIDI output and VST/AudioUnit plugins the recognition will be interrupted occasionally, but it still fully functional. Upgrade to the full version to explore a new musical experience without interruptions.
No Hardware Needed
Plug and Play
Polyphonic
Worlds first
Ultra Low Latency
Comparable to hardware solutions
Integrates with DAW
Mac, PC and iOS
Bapman
swimming with a hole in my body
"The only thing worse than a guitar is a guitarist!"
- Lydia Lunch
15 Nov 2013, 17:48
Post Re: Guitar audio till midi polyfoniskt utan extra mickar !
Jag provade lite kort med den fristående varianten och den triggade ganska bra. Men demoljuden var inte så kul att spela med. Gitarr med pianoljud känns ju ju lite sådär att spela på. Tyvärr fick jag inte den att funka med Cubase, men jag får försöka igen. Jag gillar i alla fall konceptet och det verkar funka rätt bra.
/CM
17 Nov 2013, 19:36
Fungerar väldigt bra när man ställt in ordentligt, även med en nylon ack med en transducer mick, (och den är bandlös)
och jag har mer än ett piano i test läget , ett par tre synthar och den funkar ok i Mainstage och Logic, den läser dessutom in alla Au och Vst pluggar och instrument man har.
har inte testat Cubase än.
Bapman
- Lydia Lunch
18 Nov 2013, 13:59
Jag fick med tre olika pianon, ett Roland-baserat syntljud och ett FM-synt-ljud. Jag antar att du har samma. Men om man får det att lira med sin DAW eller med sina hårdvarusyntar, så spelar ju förstås inte de medföljande ljuden någon roll.
Bendar gillade den inte när jag testade kort. Men det antar jag är in inställningsfråga. Ackord triggade inte alltid så bra heller, men även det tror jag är en inställningsfråga. Jag var ändå fascinerad över att det funkade så bra som det gjorde.
Jag kör Cubase 7.06 och där lyckades jag inte få den att dyka upp, men jag ska försöka igen, eftersom det ska funka med Cubase.
/CM
18 Nov 2013, 14:41
Som alltid med midi och Gitarr så är
inställningarna i synthen minst lika viktiga som
kontrollen, jag testade med Usb midit i min VG 99a
och det lät skit tills jag fick bend att funka med +-12 i både
kontroller och i synthen och samma med trigkänsligheten
att denna audio baserade gitarr till midi alls fungerar speciellet polyfoniskt
och pitchbend och med ett lika bra resultat som med en vanlig kontroller
och hexmick är fantastiskt.
möjligheten att plugga in sin acke ( eller el ) i macbooken ( eller PC lappen )
och köra fx samt softsynthar med ett enkelt USB audio interface är fantasktiskt.
Bapman
- Lydia Lunch
18 Nov 2013, 15:07
Den där såg jag för länge sen i en video med Quayle, hade helt glömt bort den, tack för påminnelsen.
Verkar trigga bra, även om ju Tom's spel är extremt rent och separerat oavsett hastighet.
Undrar hur mkt "slarv" den tillåter vid snabba fraser.
http://www.youtube.com/watch?v=7EfG6D9ONs0
DrSlim wrote: Äh. Jävla radhuspop för bag-in-boxpimplande Audiägare i illasittande chinos.
18 Nov 2013, 19:02
http://www.youtube.com/watch?v=P0MsBhC9TZs
Bapman
- Lydia Lunch
18 Nov 2013, 20:29
Funkar bra i Cubase 7.06, det går att spela på vilka vst-instruments som helst. Cool!
Men var hittar man stand alone-varianten (MacOS)?
19 Nov 2013, 23:39
min låg i mappen efter unzip,
bara att slänga i apps och köra
inget installationsprogram
Bapman
- Lydia Lunch
20 Nov 2013, 09:56
Min låg paketet jag laddade ner.
Vad gjorde du för att få den att funka i C7.06? Jag körde det medföljande plugininstallationsprogrammet, men jag kan inte välja den som plugin i Cubase. Måste man kanske kopiera den manuellt till någon plugin-mapp i Cubase?
Jag kör för övrigt på en Mac (OSX 10.8.5)
/CM
20 Nov 2013, 12:14
Körde installationsprogrammet och sedan kunde jag köra vst-pluggen i Cubase 7 (MacOS Mavericks). Du hittar den bland insett-effekterna på ett audio track.
Stand alone-appen startade inte vid dubbelklick, systemet gnällde över att tillverkaren var okänd. Men om jag högerklickade och valde "öppna" från kontextmenyn funkade det. Idag startar det utan problem (när datorn varit avstängd efter installationen). Vid kortare latency hänger appen sig dock. Kör RME Fireface 800 med senaste drivrutinerna, brukar funka ned till knappt 3 ms i andra sammanhang.
20 Nov 2013, 20:18
Nu hittade jag den!
Jaså du kör Cubase under Mavericks? Kul att du fått det att funka. Jag har inte vågat uppdatera musik-Macen till 10.9 än eftersom Steinberg avråder från det, i synnerhet när man dessutom kör med deras ljudinterface. Jag gillar Mavericks, så jag hoppas att Steinberg kommer med uppdateringar snart, så jag kan uppdatera OS:et.
/CM
20 Nov 2013, 22:25
Funkar bra till mini ipaden med.
Coolt att spela "No quarter"med kyrkorgel fast med gitarr då..
Kul å leka lite med.
21 Nov 2013, 00:47
/CM
Jag kör Mavericks bara på MacBook Pro, inte på musikdatorn Mac Pro. Det funkar bra, bara man stänger av den där skärmhistorian i Mission Control.
21 Nov 2013, 02:20
Marshall wrote:
/CM
Det börjar kanske bli lite OT, men vad menar du med "bara man stänger av den där skärmhistorian i Mission Control"? Jag har redan haft en Mavericks-relaterad krasch på jobbet och min kollega har precis fått en ny MacBook Pro med Mavericks (p g a av fjärde hårdvaruhaveriet med samma MBP) och är lite bekymrad över om det kommer att funka stabilt med 10.9, så alla tips är välkomna.
/CM
21 Nov 2013, 10:21
Drog ned trial-versionen och testade lite snabbt. Tyckte att den triggade lite hipp som happ trots att jag ansträngde mig för att spela rent. Ganska mycket latency, men efter att ha ändrat till ASIO i stället för Windows sound eller vad det stod så blev det rätt okej faktiskt. Testade inte med någon VSTi, bara demo-ljuden.
Inget för mig. Skulle vara kul att testa en riktig midi-mick, typ Roland GK-nånting. Undrar hur bra det triggar...?
21 Nov 2013, 16:02
/CM
Måndagsex? Min MBP är gammal, från 2010, rullar fint med Mavericks.
F.ö. angående Mavericks, "Bildskärmar har separata områden" & Cubase:
http://www.steinberg.net/forums/viewtopic.php?f=181&t=49277
21 Nov 2013, 21:19
http://www.youtube.com/watch?v=RujDWMClEio&app=desktop
Bapman
- Lydia Lunch
23 Nov 2013, 12:34
Marshall wrote:
/CM
Problemen med min gamla Macbook berodde nog på att jag hade bytt till en WD drive och de har tydligen problem med Mavericks av någon anledning http://www.idg.se/2.1038/1.531888/western-digital-varnar-for-mavericks Hur som helst sa OSX att jag var tvungen att byta HD p g a krasch, samtidigt så funkade Win7-partitionen på samma disk. Skumt.
Kollegans fyra moderkortshaverier i samma MBP kan berott på att han nästa alltid har locket stängt och använder extern skärm och tangentbord och då försämras kylningen en hel del och dåligt kyld elektronik vet man ju vad det kan ställa till med... Apple bytte hur som helst ut den.
/CM
23 Nov 2013, 18:13
Users browsing this forum: No registered users and 55 guests
