View unanswered posts | View active topics It is currently 14 Oct 2026, 22:07
Reply to topic  [ 11 posts ]
Gibson ES-359 CS Pelham Blue ltd 100pcs Ej aktuell!
Post Gibson ES-359 CS Pelham Blue ltd 100pcs Ej aktuell!
Gibson ES-359 CS Pelham Blue ltd 100pcs säljes el bytes mot en grym Les Paul i särklass,ej faded etc
gitarren är i nyskick inga dings,repor, med tillhörande CS case plus case Candy.
Bilder från photobucket: http://s1083.photobucket.com/albums/j381/busbusf18/
Fler bilder kan Mailas till seriöst intresserade
Finns i Sthlm
Demo på den specifika gurkan det gäller,köpt via Soundland Gmbh
http://m.youtube.com/watch?v=-Ombi2SmY2A
Pm via profil.
Pris 22000k Nytt Pris 20000k
specs:
The Gibson Custom ES-359 is a semi-hollow electric guitar that adds gold hardware, Grover tuners, and an ebony fingerboard with large mother-of-pearl block inlays to one of the most exciting guitars in decades: the Gibson ES-339. The ES-359 electric guitar is part of the next generation of guitars from the Custom Shop of Gibson's iconic ES electric guitars. The Gibson ES-359 delivers bold semi-hollow tone that is rich with expressive, even stinging overtones in a guitar that has reduced dimensions and weight. The Gibson ES-359 guitar also has some exciting enhancements including Memphis Tone control wiring, the 30/60 slender neck profile, and gold hardware.
Memphis Tone electronics
Memphis Tone circuitry uses 500K audio taper pots that operate with an interactive load that preserves high end as you turn down the volume. The loading effect preserves the full-bodied tone with rich midrange and singing sustain from the '57 Classic humbucker pickups while adding a very sweet bite. Another difference: the Gibson ES-359 guitar's volume is very smooth, rolling off in even increments along with the numbers on the knobs. Since they operate more like how we hear (logarithmically), the controls work the way you think they should. So when you turn down the volume, the highs are still there.
30/60 Neck
Developed with assistance from guitar guru Jon Schwartz, the Gibson ES-359 guitar's 30/60 slender neck is a '60s style neck with an extra .030" front-to-back to preserve the semi-hollow body tone, sustain, and feel while providing smooth playability.
Reduced dimensions and weight
The Gibson ES-359 electric guitar builds on the success of the semi-hollowbody guitars first introduced by Gibson in 1958 with the ES-335. Lighter and more compact than a traditional semi-hollow guitar, the Gibson ES-359 guitar retains the distinct semi-hollowbody electric tone that powered so many hit records and landmark performances.
Outer rim output jack
The Gibson ES-359 guitar's output jack is mounted on the outer rim. No more cable crossing the body spoiling your guitar's clean looks and getting in your way.
Two '57 Classic Humbuckers, with 3-way pickup selection plus individual volume and tone controls, provide the incredibly versatile sounds that make the semi-hollow electric famous for its use in jazz, rock, blues, and country. Quality Kluson tuners keep retuning time to a minimum, and gold hardware enhances the great looks.
The Gibson Custom ES-359 electric guitar comes with a Gibson Custom Shop hardshell case and a certificate of authenticity.
Check the drop-down menu to the right to select colors and/or other options.
Features
Model name: Gibson ES-359 Electric Guitar
Body type: Gibson ES-339 with reduced dimensions and weight
Body wood: maple/poplar/maple laminate
Binding: Multi-ply
Neck joint: Set-in
Neck wood: Mahogany
Neck profile: Lucille-type profile neck - more taper and fatter at the 12th fret than the ES-339
Fretboard: Ebony
Inlay: Mother-of-pearl
Bridge: ABR-1 Tune-O-Matic
Pickups: '57 Classic humbucker
Controls: volume/volume/tone/tone (Memphis Tone Circuit)
Pickup selector: 3-way
Tuners: Grover
Hardware color: Gold
Strings: Gibson Brite Wire .010 strings
Finish: Lacquer
Accessories: Certificate of authenticity
Case: Custom Shop hardshell
17 Jun 2012, 20:14
Post Re: Gibson ES-359 CS Pelham Blue ltd 100pcs Nytt Pris!!!
Nytt Pris!
18 Jun 2012, 14:22
Bilder tack!
Nu med utan att ej röra ingen knapp.
18 Jun 2012, 18:32
Pm skickat till Bulan
18 Jun 2012, 21:19
Måste vara min gamla om du inte köpt den direkt från USA?
19 Jun 2012, 08:51
Nope! som sagt, köpt via Soundland Gmbh :D
19 Jun 2012, 09:08
ahh sorry, mycket cool o snygg gitarr iaf !
19 Jun 2012, 09:24
Jajamen, den är en sån där gura man helst inte vill sälja, för att den är så oehört grym & stirrar man på färgen så drömmer man sig bort lite(förtrollande finish,hehe) :D .
Den har dock fått för lite speltid hos mig, så går lite i tankar att låta den gå vidare, men behåller den om jag inte får 20000k, den kommer att stiga i värde med några år på nacken.
19 Jun 2012, 10:06
Bulan wrote:
Bilder tack!
Bilder skickade via mail.
19 Jun 2012, 16:41
Post Re: Gibson ES-359 CS Pelham Blue ltd 100pcs Nytt Pris!!! BIL
Ursäkta kladd men..
Är 359an för 339an samma som 355an är för 335an? Upphottad med Custom utseendet?
Elsträng och Hammare
19 Jun 2012, 22:12
Hasse-Angerfist wrote:
Ursäkta kladd men..
Det skulle man väl kanske kunna säga block inlays ist för dot,custom huvud, Lucille profil på halsen,single ply-binding,
Rosewood ist för ebenholtz bräda lite enklare i sitt utförande skulle jag säga,denna gitarr är det mkt kärlek nedlagd på vid bygget :D
19 Jun 2012, 22:22
