Här kommer en text som jag sparade ner från Internet någonstans för flera år sedan. Nu hittar jag inte den där igen, men jag kopierar den hit.
Som vanligt ska man kritiskt granska ALL information och jag är inte helt säker på att t.ex. informationen precis i slutet om vilka primära lastimpedanser olika stärkaretillverkare använt stämmer helt och hållet. Den stämmer till stor del med annan information och med utgångstrafos jag mätt upp, men jag undrar om en del värden...
_________________________________________________________________________________________________________
<font size="4"><b><u>LOAD IMPEDANCE</u></b></font id="size4">
<i>Load Impedance is one of those "grey" areas in amp design, which can be very confusing. How is the correct impedance value derived for an amp circuit? Is there one "correct" value? What happens if we change the load impedance? Curious? Read on..."]
Below is a page taken from Engineering Electronics, Ryder, John D. McGraw Hill 1957. (Used without Permission). We'll base our brief discussion on this figure, & we'll use as little math as possible!
To the left is the graph of plate voltage versus plate current in a 6L6 output tube. These kinds of charts can be found in tube manuals, as well as on the Triode Electronics website (
http://www.triodeel.com/). What's key to understand is that the screen voltage is fixed at some value, and then the plate voltage is varied for a fixed bias voltage. The current changes are recorded and the whole thing is graphed. The black 'horizontal' lines on the upper graph represent bias settings on the control grid. The diagonal lines represent different load impedances. A bias setting of -13.5V has been selected as the operating point. This corresponds to a plate voltage of 250VDC. The input signal will 'swing' the bias up to zero, and down to -27V. As this happens, the plate voltage and current will change as well, which represent the output power in the plate circuit.
In an ideal class A amplifier, the operating point (-13.5V) would be equidistant from the end points on the load line. In English, you could follow a particular load line, say the 4,000 ohm line, from where it intersects the Eg=0 (zero bias) line to the operating point (-13.5V) and then again from the operating point down and to the right to where it finally reaches the max bias (Eg=-27V) and the two segments would be equal in length. The length of the line represents the output tube signal swing (as voltage and current) and naturally for linear operation you want the top and bottom of the input signal to get amplified the same amount. The tube swings from minimum voltage (maximum current) to maximum voltage (and minimum current). Follow along the load line to see that in action
The slope of the load line is simply the reciprocal of the load impedance: if the load is 4,000 ohms, then the slope is 1/4,000. Once you have your slope, you can draw your line. Draw the load line through the operating point (idle) and you can then solve for everything else mathematically. There are numerous sources for the applicable math including the RCA Tube manuals, the RDH, etc.
If you look at the other load lines, 2,000-ohm, 1,500-ohm and 1,000 ohm, you'll notice that the load line gets more 'vertical' and the segment from the operating point to the zero-bias curve gets longer while the other segment (operating point to max bias) gets shorter, indicating increasing distortion, particularly even-order. Notice also that the peak current increases as the load impedance decreases. As the load impedance gets lower, peak current draw increases (see the upper left end of the load line by Eg=0), which can be a problem if it exceeds the tube's dissipation rating for too much of the operating cycle. Just as when you bias an amp, there is a dissipation value at each of the points along each load line. Simply multiply the current value times the voltage at that point. In fact, you will often see a maximum dissipation line graphed alongside the operating curves, which is the dotted line that arcs across the chart in this case. To graph it, simply find the points on the chart where the voltage times the current (in amps) equals the rated dissipation in watts and connect them. You can see that 1/2 of the cycle is completely over the dissipation rating for the 1,000-Ohm load line in the chart above.
You can see something else from the chart that is unique to class A amplifiers: notice that the idle point (-13.5V) is on the maximum dissipation curve. As an input signal starts the plate voltage swinging, notice that the load line moves away from the maximum dissipation line. The amp actually runs hotter at idle than it does at full undistorted output.
Finally, have a look at the lower chart. This graphs distortion and power output against load impedance. Generally speaking, a designer will attempt to reconcile the most efficient power output with the minimum distortion. You can see from the chart that as you alter the load impedance, the power output as well as distortion products change. For these operating voltages and this tube, 3,800 ohms is probably the optimum load.
So, how do you know which impedance to use? A good starting point is to look at what's been used in the past with similar circuits. Ultimately, it all comes down to intangibles like "tone" when one is talking of a musical instrument amplifier. 'Tone' is not easily defined in black and white by any one variable like plate voltage or harmonic content. If you're going for a classic "Fendery" clean sound, you'll probably want to use that style of output transformer, as you would other types for their specific tones. Below, I've listed some approximate values for common guitar amps to get you started
Marshall, 50W, 2xEL34: 3400 Ohms
Marshall, 100W, 4xEL34: 1750 Ohms
Marshall JTM45, 2xKT66: 8000 Ohms
Vox, 30W, 4xEL84: 4000 Ohms
Vox, 15W, 2xEL84: 8000 Ohms
Fender, 50W, 2x6L6: 4100 Ohms
Fender, 100W, 4x6L6: 2000 Ohms
Tweed-Spec Cathode Bias, 6L6, p-p: 6600 Ohms
Matchless, 15W, 2xEL84: 4000 Ohm
Matchless, 30W, 4xEL84: 4000 Ohms
Park, 50W, 2xEL34: 5000 Ohms
Informationen fanns på
http://www.obsoleteelectronics.com/Tran ... edance.htm men där verkar den inte finnas längre.
Sven-Johan
Rörförstärkartekniker
<i><font size="1">Förundras över att det är i stort sett olagligt med graffiti och gatukonst samtidigt som alkohol, hundar, fotboll och bilism är tillåtet...</font id="size1">"]
