View unanswered posts | View active topics It is currently 14 Nov 2026, 06:35
"Digital Intelligent Valve Optimisation"
Post "Digital Intelligent Valve Optimisation"
http://thetoneking.com/wp/orange-amps-launches-divo-tube-bias-technology/
http://www.youtube.com/watch?v=Mkdwbl8gf3c
[quote] For over forty years Orange amps has pushed back the boundaries of guitar amp technology and at NAMM 2011
The company is proud to announce a worldwide exclusive distribution agreement for DIVO Tube Sync, a truly revolutionary new guitar amp technology. Here’s how Orange describes the technology:
The new DIVO technology automatically adjusts the bias of the output power tubes to ensure their full potential is realized. It monitors the amp’s performance and will isolate faulty tube failures, by running them at half power until the tubes can be changed. The DIVO system also increases the reliability of amplifiers by maintaining the optimum performance of the tubes by performing an ‘in circuit’ test every time the amplifier is powered up.
Musician's Friend Stupid Deal of the Day
DIVO technology opens up a whole new dimensions in tone options allowing for the first time ever the ability to mix and match tubes. You can experiment with an EL34, 6L6, 6550, KT77 or any other tube type all at the same time in the same amp. With DIVO the Tubes are automatically matched.
DIVO will extend the lifespan of your tubes and never again pay a tech to re-bias
DIVO can be easily integrated into any almost any guitar tube amplifier.
Orange amps will be offering this as option in their new Rockerverb 100 which will be “DIVO Ready.â€Â
15 Jan 2011, 11:39
Har blivit erbjuden att köpa dessa boxar för att ha i mina förstärkare. Det känns som att skjuta mygg med kanon, aningen overkill. Boxen kostar mellan 1500-2000:- & kan möjligen justifieras på stoora förstärkare som skall gå på arenor för att ge högre driftsäkerhet. Boxen adderar ju själv till komplexiteten & vad gör man när den strular?
Tror att tekniken är tagen från ngt annat sammanhang t ex processtyrning, sedan har man anpassat & produktifierat för rörstärkare.
http://www.tubesync.co.uk/
Ola
http://www.lehnert-amps.com
21 Jan 2011, 09:53
Jag blev också tilltalad av nån agent på göteborgsmässan. Min favoritfråga när det gäller teknologi passar bra här: Vilket problem är det här lösningen på? Jag misstänker att nån har fått en idé utan att riktigt ha pejl på hur "problemet" ser ut i realiteten. Undrar hur mycket Orange betalat för sina kort? Agenten på mässan lät med en gång förstå att det naturligtvis blir lite högre pris för småhandlare... inte precis nåt man vill höra av en försäljare på första dejten!
"The Tone is in your pants"
http://kuhnamps.com
21 Jan 2011, 12:39
Jag träffade samma individ på Fuzzmässan. Han erbjöd sig att skicka ett exemplar av mojängen för test. När jag beskrev jag vill testa med rörpar som diffade 100% på tomgångström (t.ex. 15 och 30ma)vid samma B+ och gallerförspänning så blev det tyst och ngt provexemplar kom aldrig.
Jag tolkar det som bekräftelse på principen: man kan kompensera upp till ca 15% skillnad i tomgångström/biasspänning utan att det börjar låta konstigt. Detta slår ju ett hål i deras marknadsargument.
Däremot tycker jag de inbyggda säkerhetsmekanismer är av större nytta än biasautomatiken.
Sedan skall vi inte glömma att ett liknande system demonstrerades på sista KOC workshopen i Maj 2004: http://www.londonpower.com/wks04swe.htm
21 Jan 2011, 13:14
Det är väl något liknande detta som dom använder?
i såfall ingen nyhet.
Controller Board for the Autobias System
The digital auto-bias feature is represented by an on-board 8 bit microcomputer that during warm-up or, at any time at the press of a front panel button, sets grid bias on each output tube to the value required to produce exactly equal plate currents of optimum value, provides indication of faulty tubes and eliminates the need for matched stets. The digital circuitry is not in the signal path. When calibration is complete, it becomes inactive and shuts its internal clock off, while maintaining the bias settings in digital storage.
22 Jan 2011, 01:14
Precis min tanke när jag läste om det där systemet. Det påminner mig lite om det här:
http://gamechanger.music-man.com/
Dvs, coolt vad man kan åstadkomma med lite digital teknik, men det betyder inte att det är användbart eller eftertraktat.
Erik R
22 Jan 2011, 18:29
Users browsing this forum: Google [Bot] and 10 guests
