View unanswered posts | View active topics It is currently 27 Sep 2026, 01:46
Reply to topic  [ 17 posts ]
1973 Gibson Les Paul Custom natur m lönnbräda
Post 1973 Gibson Les Paul Custom natur m lönnbräda
Fint skick, bytta mikar (kåpor original), skön hals, låter finemang. <s>22000:- </s>
Sänker priset till 21000:-. Kom gärna och känn på denna sköna gitarr i Vasastan, Stockholm.
Jag har bilder som jag kan maila.
Finns i centrala Stockholm, hämtas helst då case saknas.
16 Feb 2009, 03:06
Byten? Något speciellt av intresse?
16 Feb 2009, 19:44
Hej, byten är helt ok. Är väl intresserad av det mesta Fender/Gibson gitarrer och basar- 70-tal eller äldre. Även andra gamla godingar kan vara intressant.
Svara här eller maila till 1gunnar >at< gmail.com
mvh Gunnar
16 Feb 2009, 20:07
...jag kan även lägga en slant emellan om du har något extra kul att byta bort... [:)]
16 Feb 2009, 20:10
Jag har en nästan sprillans Firebird som jag inte använder. Kan det va nåt?
17 Feb 2009, 20:47
Hej, tyvärr inte. Är mest inne på gamla prylar.
19 Feb 2009, 14:36
en vox ac10 twin i nästan nyskick typ kondition 9/10....JMI såklart
19 Feb 2009, 19:00
Hej, det kan vara intressant. Är det med blågrå panel?
19 Feb 2009, 22:27
japp de e det. vet inte om jag skall behålla den eller inte. vad e det för mickar på din...
20 Feb 2009, 00:48
Den ena är en modernare Gibson, den andra kommer jag inte ihåg men det var något som lät bättre än Gibson-mikarna...[:)]
20 Feb 2009, 03:12
vad e det för serienummer och vad säger potstämplarna...?
20 Feb 2009, 09:09
Ett sexsiffrigt nummer som börjar på 6, får kolla potarna ikväll.
20 Feb 2009, 10:04
Hej igen, har en AC10-fråga:
Jag har redan en AC-10 twin från ca ´65. Den låter klart "mörkare" än t ex min AC30 från samma år. Är det likadant med din eller börjar min bli trött och behöver översyn?
21 Feb 2009, 04:01
Hej! Vilken kanal låter din mörk på? Det sitter ju ef86 rör i vibratokanalen på dessa och dom brukar ge en något brunare(mörkare) ton tycker jag. Men om båda kanalerna levererar samma mörka karaktät så kan det ju vara något annat. tesa att byta slutrören o kolla om det händer något...
21 Feb 2009, 12:45
Framför allt, när byttes elektrolytkondingarna i stärkaren? "Vintage tone" beror ofta på kassa elektrolyter...[:)]
/Lennart
http://www.specter.se
21 Feb 2009, 17:01
Hej boys, tack för svar. Jag tycker nog båda kanalerna låter lika. Ska experimentera med rörbyten. Kondingarna har inte bytts så länge jag haft stärkaren och jag tror knappast att förra ägaren gjorde någon recap..[:)]
21 Feb 2009, 22:12
Sänker priset till 20000:-. Kom gärna och känn på denna sköna gitarr i Vasastan, Stockholm.
20 Jun 2009, 17:59
Users browsing this forum: Google [Bot] and 44 guests
