guitarhussler
 Fulltone 69 som bara fungerar med batteri
Är det någon som kan hjälpa till att fixa eller tipsa om varför min 69 bara fungerar med batteri.
/Mattias
| 27 Nov 2008, 22:02 |
Ahab
Kollat sladdarna så ingen lödning har släppt?
| 27 Nov 2008, 22:10 |
guitarhussler
Nej dom ser okej ut. /M
| 27 Nov 2008, 22:13 |
polifemo
Är det inte så att vissa Fuzzar ska ha en batterieliminator med "positive tip"?
| 27 Nov 2008, 22:39 |
Tubis
Joined: 27 Dec 2007, 15:16 Posts: 7525 Location: Uddevalla
Ser ut som plus är jord vad jag kan se på scheman vilket inte betyder nått igentligen men polifemo har nog en stor poäng.....
| 27 Nov 2008, 22:48 |
guitarhussler
Hur ser en sådan ut? batterieliminator med "positive tip"?
/M
| 27 Nov 2008, 23:16 |
albert
Har en treble booster som bara funkar med batteri eller eliminator med <i>isolerade "] uttag. Den funkar alltså inte med min Fuel Tank men utmärkt med egen adapter. Samma med din fuzz kanske? Mats
| 27 Nov 2008, 23:24 |
polifemo
Osäker på det här...
Såhär skriver Stinkfoot: <i> Forget the terms "negative tip" and "positive tip" - those terms apply to the 1/8" mini tele plug that to my knowledge now only is used on the ProCo RAT, the Ibanez reissue TS-808 and the old-style DOD pedals (all of which want a positive tip, btw).
You might also find one or two Electro-Harmonix pedal in this group (beware, though - not all of the E-H pedals use 9 volts DC). All other "normal" pedals use a 2.1mm barrel type plug, with the positive carried on the outside of the plug. The center pin in the adapter jack is therefore negative, and the term is "center negative". But plug polarity is one thing - ground polarity is another thing you need to know about. Again, most pedals (all "normal" effects such as Boss, Ibanez etc) are the same - they have negative ground (battery "-" goes to ground). But some effects - mainly "boutique-type" germanium fuzz pedals - have positive ground instead. On those pedals, the adapter jack polarity is normally also reversed, but they don't have to be - it doesn't have anything to do with the fact that they are positive ground.
The main thing to remember is that you can't feed these pedals power from the same source (daisy chain or non-isolated psu) as you use for the others - that will short the entire power supply out, and make your pedals go quiet (at best - at worst, your gear will be damaged). For those pedals, you have to either use batteries, get a separate adapter (check the plug polarity), or get a psu with isolated outputs. Check the list above - there are only a handful of power supplies with isolated outputs."]
| 27 Nov 2008, 23:28 |
Ahab
Polifemo: Det betyder att + på batteri/eliminator är kopplad till jord och elektroniken drivs på negativ spänning, som gamla fuzz face..
| 27 Nov 2008, 23:44 |
gammelnalle
I wanted to be able to use this with a standard power supply, but being a PNP circuit the positive is connected to the ground(sleave) of the input, where as most normal effects(that use a positive power supply) have the negative connected here. After posting a message on Ampage I got directed to the AMZ solution to this. Ths AMZ schematic is for the standard fuzz face. I’ve updated this for the ‘69 modifications: ‘69 fuzz layout / ‘69 fuzz schematic Small Bear Electronics - Parts / Guitar Gadgets - Fuzz Face Boards & Schematics / EDIT: OOOPS Glömde VAR: http://images.google.se/imgres?imgurl=h ... v%26sa%3DNGeofex - Technology of Fuzz Face / AMZ - PNP Fuzz Face with positive power supply kanske kan vara till hjälp b
| 28 Nov 2008, 08:36 |
albert
Det var mycket engelska här för att säga samma sak: Effekter med germaniumtransistorer verkar känsliga för icke-isolerade adapters. Precis som någon engelsk text konstaterar, kortsluter effekten hela kedjan. Kör fuzzen genom egen adapter eller med batteri. Batteri är faktiskt oftast helt OK, för dessa effekter drar nästan ingen ström alls. Många hävdar t o m att de låter bättre med batteri, särskilt gammaldags brunstensbatterier (jag hör inte mycket skillnad). Mats
| 28 Nov 2008, 20:36 |
d95err
Joined: 08 Jan 2008, 10:48 Posts: 1988 Location: Uppsala
Jag byggde en Rangemaster-klon med PNP germanium-trissa. Då löste jag det med att helt enkelt leda +9V till det som på schemat är jord och jord till det som på schemat är -9V. Möjligen var det ytterligare någon liten förändring. Funkar i alla fall hur bra som helst med en vanlig 9V adapter, även om den matas parallellt med andra effekter.
Erik Runeson
| 28 Nov 2008, 20:52 |
Tubis
d95err wrote: Jag byggde en Rangemaster-klon med PNP germanium-trissa. Då löste jag det med att helt enkelt leda +9V till det som på schemat är jord och jord till det som på schemat är -9V. Möjligen var det ytterligare någon liten förändring. Funkar i alla fall hur bra som helst med en vanlig 9V adapter, även om den matas parallellt med andra effekter.
Erik Runeson
Jord är väll förbundet med allt vilket skulle innebära att du kortsluter matningen om du gör så? Dvs du har ett antal parallella matningar som alla är förbundna jordmässigt genom telekablarna. Sen lägger du plus på jord i en pedal och vips, kortis.
| 28 Nov 2008, 21:16 |
d95err
Tubis wrote: d95err wrote: Jag byggde en Rangemaster-klon med PNP germanium-trissa. Då löste jag det med att helt enkelt leda +9V till det som på schemat är jord och jord till det som på schemat är -9V. Möjligen var det ytterligare någon liten förändring. Funkar i alla fall hur bra som helst med en vanlig 9V adapter, även om den matas parallellt med andra effekter.
Erik Runeson
Jord är väll förbundet med allt vilket skulle innebära att du kortsluter matningen om du gör så? Dvs du har ett antal parallella matningar som alla är förbundna jordmässigt genom telekablarna. Sen lägger du plus på jord i en pedal och vips, kortis. Givetvis funkar det inte att koppla +9V till signaljord. De punkter som skulle ha letts till jord kopplas istället till +9V. De punkter som skulle varit -9V kopplas till signaljord. Komponenter utanför kopplingskondningarna vid input och output (typ "bleeder" motstånd) kopplas till jord som vanligt. Här är schema att jämföra: Positiv jord (orginal): http://www.generalguitargadgets.com/dia ... _sc_pp.gifNegativ jord (som min pedal): http://www.generalguitargadgets.com/dia ... _sc_pn.gifEDIT: Jag har gjort motsvarande med min Fuzzface klon, och det funkar också bra. Båda körs utan problem med andra pedaler på samma 9V-kedja. Erik Runeson
| 28 Nov 2008, 23:36 |
Tubis
d95err wrote: Givetvis funkar det inte att koppla +9V till signaljord. De punkter som skulle ha letts till jord kopplas istället till +9V. De punkter som skulle varit -9V kopplas till signaljord. Komponenter utanför kopplingskondningarna vid input och output (typ "bleeder" motstånd) kopplas till jord som vanligt. Här är schema att jämföra: Positiv jord (orginal): http://www.generalguitargadgets.com/dia ... _sc_pp.gifNegativ jord (som min pedal): http://www.generalguitargadgets.com/dia ... _sc_pn.gifEDIT: Jag har gjort motsvarande med min Fuzzface klon, och det funkar också bra. Båda körs utan problem med andra pedaler på samma 9V-kedja. Erik Runeson Okej, jag fattar, man blir ju lite smått snurrig men det är väll bara potentialskillnader och rätt polaritet igentligen som krävs för att allt ska funka[:I]
| 28 Nov 2008, 23:57 |
d95err
Tubis wrote: Okej, jag fattar, man blir ju lite smått snurrig men det är väll bara potentialskillnader och rätt polaritet igentligen som krävs för att allt ska funka[:I]
Ja, det är inte lätt att förklara sånt här med bara text. Ett kopplingsschema säger mer än... Erik Runeson
| 29 Nov 2008, 00:44 |
