View unanswered posts | View active topics It is currently 06 Nov 2026, 17:43
vintage tint (igen)
Skokräm!
... har jag hört ;)
Fördelen ska visst vara att det är enkelt och ofarligt... nackdelen att man måste göra om det någon gång per år. ;)
24 Feb 2008, 21:52
http://www.reranch.com/fenderneck.htm
Kanske ?[:p][:p][:p]
24 Feb 2008, 22:23
Det såg mer ut som betsningsglädje[:0]
OK Vintage-gulnat alltså[:p]
24 Feb 2008, 23:16
Här är skokrämstricket
I tinted the satin finished neck on my Jimmie vaughan Strat...it was WAY too white.....
brown kiwi shoe polish in light applications, and oooo steel wool on the back of the neck after it set up and was buffed, to remove stickiness. Lemon oil rubbed in/on and really rubbed for a couple of days, and you would never know, it looks pretty natural, without looking like years in a smokey bar for a 3 year old guitar...(you know - phony)....
None the less it is only slightly tinted, and not carmel brown. the rest will come in time. This thIng was just WAY too white!
Och vad du förmodligen är ute efter:
24 Feb 2008, 23:25
Users browsing this forum: Google [Bot] and 55 guests
