View unanswered posts | View active topics It is currently 27 Oct 2026, 21:06
Revv D20
Post Revv D20
Hej
Fundera på att sälja min Revv D20 topp.
An inspiring all-tube clean & crunch amp with Two notes Torpedo-Embedded reactive load & virtual cabinets.
All tube. ~9lbs. 20 or 4 watt operation.
World-class clean & crunch tones developed with Nashville session greats.
Two notes reactive load & virtual cabinets built in.
FXLoop, MIDI, & more.
Buld your own rig with amp-voiced pedals for high gain.
Traditional, cabless, or hybrid. Recording, live, & home. D20 has you covered.
Overview
The D20 is the world’s first Two notes Torpedo-Embedded amplifier. This all-tube head has an optional reactive load for organic feel & tone when playing without a cab & hosts virtual cabinets onboard for direct recording, silent playing, & live performance without a microphone.
We set out to build an amp that not only has this new modern featureset but sounds incredible on its own as a standalone amplifier. The result is something convenient & great sounding at the lowest price point Revv has ever had.
Features
Inspiring Clean & Crunch tones developed with Nashville sessions guitarists
Perfect platform for your favorite gain pedals
3-band EQ + Volume & Gain controls
Push/Pull gain pot for 2nd crunchier voicing
Switchable from 20 to 4 watts
2 6v6 – 2 12ax7
Buffered Series FX Loop
Switchable 4/8 Ohm speaker jack
Embedded Two notes Reactive Load & Virtual Cabinets
Go direct to Front of House, interface, or headphones – without a cabinet.
Hundreds of virtual mics, speakers, cabinets, EQ, reverb, & more available.
XLR Balanced Direct Output, USB, & Ground Lift for Torpedo Embedded
6 Pre-Loaded Virtual Cabinets selectable via front knob – all customizable. Or up to 128 via MIDI.
“Pre & Post” switch selects whether (in reactive load direct mode only) the power amp is in the signal chain. This is so you can take advantage of Two notes’ power amp simulation & dramatically change the character of the D20 with virtual tubes such as EL84, if you like.
Reactive Load automatically engages when speaker is not detected to preserve amp
Select Between Internal & Speaker Load
Level-Adjustable Headphone Out
Small, Light, & Durable
6.3125″x7.5″x12.3125″ including knobs, not including handle
High Quality Transformers
Easily Accessible Rear-Bias Test
Easily Accessible Fuse
Durable, Lightweight Aluminum Enclosure
Weighs ~9lbs
LED-Illuminated Badge
Kan skickas emot fraktkostnad
Pris 8900kr
05 Apr 2021, 21:04
