View unanswered posts | View active topics It is currently 31 Oct 2026, 12:22
Bearfoot OD Sparkling Yellow 2 SÅLD
Post Bearfoot OD Sparkling Yellow 2 SÅLD
Bearfoot Sparkling Yellow pedal. Low till Medium OD. Handmålad, några dings SÅLD
From Bearfoot:
Voltage is 5V-15V to vary the headroom.
Early American tones…Tweed – Plexi – Blonde – Brownface…not just the sound but the feel as well. The SY2 is voiced more for running into American amps/speakers…not as bright and a little more compression. Volume and Drive controls are standard. The M and T controls are a very versatile EQ section that can also be used as an EQ with the drive down. The M control is for low mids and helps cover the various cabinets and speakers you find from Deluxes up through Showman and Bassman configurations. And the M controls pre-distortion so it also affects the saturation of the drive and will push past the vintage tones into blooming distortion and even fuzz like tones. And finally, the post-distortion Treble control is there to get the sound just right.
Kan hämtas hemma hos mig i Göteborg,
eller kan skickas med blå påsen (+63kr).
image sharing
11 Nov 2019, 21:27
Post Re: Bearfoot Sparkling Yellow overdrive 2
BEHÅLLER
03 Dec 2019, 21:07
Post Re: Bearfoot OD Sparkling Yellow 2
Ville sälja den, sen ångrade mig, nu til salu igen!
15 Oct 2020, 10:49
SÅLD
08 Nov 2020, 15:43
