View unanswered posts | View active topics It is currently 28 Oct 2026, 13:00
Visual Sound V2 Jeckle & Hyde for Xotic EP Booster or OCD
Post Visual Sound V2 Jeckle & Hyde for Xotic EP Booster or OCD
I have a Visual Sound V2 Jekyll & Hyde Overdrive & Distortion pedal that I'd like to trade for a Xotic EP Booster or Fulltone OCD version 4. My pedal is a few years old, functions & sounds great, and has velcro under.
From its first appearance in 1997, the Jekyll & Hyde was the first pedal to combine two separate effects in one pedal. The V2 Series gives the same great tone guitarists have come to love plus an added noise reduction system. Each channel of the Jekyll & Hyde has separate controls, giving you the ability to use them separately, or together. All of this adds up to one of the most versatile distortion/overdrive pedals on the planet!
The overdrive side is like an 808 tube screamer, but with a separate bass boost switch, and the distortion side has many tones, but to be honest, since I play mostly country, I haven't used that hardly, so the best thing to do is to youtube a clip of it in action.
Let me know if you have any questions...
P.S. I also have a Visual Volume that I'd also do this trade with instead of the overdrive/distortion.
P.S.S. You can write back in Swedish if you're not comfortable with English.
09 Dec 2014, 17:08
Post Re: Visual Sound V2 Jeckle & Hyde for Xotic EP Booster or OC
Bump
13 Dec 2014, 18:30
