Före detta Gibson
Joined: 01 Mar 2008, 21:29 Posts: 1106 Location: Nedre Norrland
 Re: Fulltank Chamaleon
T-Rex Fuel Tank Chameleon, multi-output power supply for effect pedals, 1.500 mA through 6 isolated Outputs, outputs 1-3 can thomann be set to either 9V DC or 12V DC, output 4 can be set to either 9V DC or 18V DC, outputs 5 and 6 offer 9V DC/12V DC and 12V AC respectively, but only one of these two outputs can be used at a time, In all thomann 5 simultaneous outputs, each supporting one or more pedals, all 9V and 12V outlets deliver 300mA each, when outlet 4 is switched to 18V DC it delivers 150mA, all outlets are center negative, voltage selector 115/230 volts, green LED when unit is on, size (W x H x thomann D) 160 x 39 x 81 mm, weight excl. packaging 0,800 kg. Included: 1 x 100cm Mains power cable, 1 x Black link cable with five 2,1mm - 2,1mm connectors, 1 x Red 50cm DC cable with 2,1mm - 2,5mm connectors for use on the 12V AC outlet thomann port, 1 x Blue 50cm AC cable with 2,5mm - 2,5mm connectors for use on the 12V AC outlet port, 1 x Black 50cm DC cable with 2,1mmDC - 3,5mm mini-jack connectors, 2 x 20cm DC cables with 2,1mm -2,1mm connectors, 4 x 50cm DC cables with 2,1mm thomann -2,1mm connectors, 1 x 75cm DC cables with 2,1mm -2,1mm connectors, 1 x 100cm DC cables with 2,1mm -2,1mm connectors
