View unanswered posts | View active topics It is currently 13 Oct 2026, 17:29
Höfner mot Plåtniklas
Post Höfner mot Plåtniklas
Jag har en Höfner 463/S från 1956.
Fullt spelbar och med låg stränghöjd. Fet hals. Lite rassel runt 10:e band. Feta orginalband i gott skick, som aldrig blivit slipade. Kanske räcker en bandslip för att eliminera rasslet. Höfner hade inte kommit på det där med trussrod 1956. Jag har monterat en K&K Pure Archtop pickup. Strängad med Thomastik Jazz .012 (skulle nog gilla .013)
Specar:
"Sixteen inch-wide, three and a quarter inch deep archtop, weighs just 4.80 lbs. and has a nut width of just over 1 9/16 inches and a scale length of 25 1/4 inches. Two-piece carved close-grain spruce top, one-piece carved ribbon mahogany back, and ribbon mahogany sides. Medium-to-thick profile, three-piece maple neck with a two mahogany center strips. Two-layer (mother-of-peraloid and black) neck heel onlay. Brazilian rosewood fretboard with original triple-layer (white/black/white) nut, 'zero' fret and 22 original jumbo nickel-silver frets. Block shaped fretboard markers with inlaid eleven-piece mother-of-pearl, tortoiseshell, black and white strips. The top and bottom of the body are very ornately bound with a thick white binding on the sides and half-herringbone 'rope' purfling around the top and back. The f-holes are single-bound and the neck is triple-bound. Headstock with three-strip pattern of white mother-of-pearloid and tortoiseshell with arrow shape outline inlaid in white. Three-in-a row open-back strip tuners with white oval plastic buttons. Rosewood height-adjustable bridge with adjustable fret-wire inserts. Nickel-plated escutcheon 'Lyre' tailpiece with "Hofner" engraved on wide bar, secured by two pins and one screw. The "Hofner" logo is impressed (in black) into the spruce top, just below the treble foot of the rosewood bridge."
En scanning av den utrikiska delen av internet antyder priser mellan $1500 och $3500.
Några skäl att anta att min 463:a inte är värd $3500
- Sverige är inte USA.
- Den är inte i mint condition.
- Det cirkulerar rätt många billiga plywood-Höfner som nog sänker priset på de solida modellerna.
- Den har några dings. En har orsakat en spricka (8 cm, sluten) nedanför nedre f-hålet. Det finns ytterligare en spricka (14 cm, också den sluten), vid "nedre hornet".
- Halsen har blivit omsatt med lite för flack vinkel, varför jag tvingats ta bort rattarna för höjdjustering av stallet och slipa ner några mm av stallet, för att få den spelbar (delarna finns kvar).
- Halsen har fixerats i klacken med en skruv genom greppbrädan. Skruvskallen har sedan, inte helt osnyggt, dolts av en plugg i rosewood.
- Jag har bytt stämskruvar (de gamla finns kvar, saknas ett plastvred).
- Plektrumskyddet är nytt (men av rätt modell).
Jag är sugen på en plåt-resonator i minst "högre budgetklass", t ex Messer, Busker eller Republic. Bisquit eller tricone. Gärna med pickup.
463:an har inget case, så skicka kan bli bökigt. Jag finns i Gbg men är i centrala Sthlm 6-7 maj, om det kunde glädja någon..
29 Apr 2013, 23:18
Post Re: Höfner mot Plåtniklas
Ok, den kanske är snygg där på väggen, resonatorgitarren. Men du, ärligt talat, när spelade du på den senast? :wink:
04 May 2013, 18:38
Users browsing this forum: Bing [Bot] and 13 guests
