View unanswered posts | View active topics It is currently 14 Oct 2026, 09:04
Vintage 30MF mot G12-65 eller liknande.
Post Vintage 30MF mot G12-65 eller liknande.
2 st på 16 ohm bytes mot 2 G12-65 eller två greenbacks kanske, dessa ska då också vara på 16 ohm vardera.
"The Vintage 30MF is a special speaker celestion made for marshall with a little lower frequency response than the standard model. Its the same as what Avatar sold, relabled as the Hellatone 60L. It basically has a bit more lows than the standard version, can handle 70 watts instead of 60, and its supposed to have a bit smoother upper mid bark over the standard v30."
http://www.voodooaudio.se
27 Jan 2012, 21:18
