View unanswered posts | View active topics It is currently 06 Oct 2026, 01:23
Vox VT100 mot något mindre
Post Vox VT100 mot något mindre
Spelar mindre och har inte behov av 212 och 100w
Jag har:
En VOX VT 100 212. Ny i april, nyskick, lämnat hemmet två gånger. Inkl fotpedal.
Se nedan!
Söker:
Något mindre skrymmande och lättare, Fender Cyber Deluxe, Fender Blues Junior mm.
http://www.youtube.com/watch?v=jLmci_K3CKc
Sophisticated modeling technology combined with the VOX Valve Reactor power amp circuit that uses a 12AX7 vacuum tube results in sound quality that overwhelms the competition. Announcing the VT series --- the latest combo amps in the Valvetronix series, featuring simulation sounds of famous guitarists.
VOX Valve Reactor circuit that uses a 12AX7 to produce real tube power amp sound.
Twenty-two realistic amp models are built-in, ranging from the latest high-gain types to unobtainable legendary boutique amps and vintage amps.
Twelve high-quality effects including independent reverb, rivaling the quality of dedicated units
Three banks (basic, effected, and song) are provided for each amp model, giving you a total of sixty-six preset programs.
Twenty-two programs of "song presets" simulate the sounds of famous guitarists.
You can save eight of your own edited programs.
Power level control allows you to adjust the output wattage of the power amp, meaning that you can obtain that distinctive power amp distortion even at low output levels.
Headphone output lets you practice at home, even at night.
The VT50/100 provide an external speaker output, and the VT100 provides an effect loop for expandability.
By using the VFS5 foot switch you can use your foot to change programs or turn effects on/off.
Lånde bilder:
/Bilton
bilton[snabela]telia.com
24 Aug 2010, 21:09
Bumpar!
Ingen som har något?
Fender högtalarlåda kan vara intressant!
/Bilton
04 Sep 2010, 09:21
Users browsing this forum: Bing [Bot] and 16 guests
