View unanswered posts | View active topics It is currently 24 Sep 2026, 09:44
Inte Aktuell
Post Inte Aktuell
Få höra vad ni har att erbjuda..
Ska dock vara f-spaced eller trembucker..
<i>"F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm)""]
<font color=green>Skavis</font id=green>
<font color=red><i>You can check out anytime you like but you can never leave.."]</font id=red>
http://www.stormvarning.net/ : http://jojjo5.tripod.com/
Edited by - Skavis on 07 July 2003 13:33:39
07 Jul 2003, 09:50
51mm???
Jag tycker mer att det rör sig runt 53mm.
Är det mått på halsmick?
07 Jul 2003, 11:01
Ingen aning men jag har hittat en mick i GMF:s skrotlåda..
07 Jul 2003, 13:33
Users browsing this forum: No registered users and 55 guests
