[ 2 posts ] |
Digidesign 002R m protools 8 bytes
turbojugendt
Lånar lite info från nätet: A summary of the hardware specifications of the Digi 002 Rack make for good reading: Firewire connectivity. Eight analogue inputs and eight analogue outputs, all balanced. Inputs 1-4 have mic preamps with 48V phantom power, switchable in pairs. Eight channels of ADAT optical I/O or two channels of S/PDIF I/O. MIDI In and two MIDI Outs. A-D and D-A: 24-bit at 44.1, 48, 88.2 and 96kHz sample rates. Outputs 1 and 2 mirrored on quarter-inch TRS monitor outputs and RCA outputs. Alternate Source input on RCA connectors for monitoring tape players, CDs and so on. Maximum input levels: mic +3dBu, line +18dBu. I/O frequency response: +0.15/-0.5 dB, 20Hz-20kHz. Input dynamic range: 101dB A-weighted on inputs 1-4; 108dB A-weighted on inputs 5-8. Output dynamic range: main outputs 114dB, Monitor outputs 112dB, outputs 3-8 114dB, Alt outputs 98dB (all A-weighted).
Inklusive protools 8 mjukvara. Ljudkortet fungerar givetvis med andra program också.
Bytes mot något skoj, gärna en gitarr eller delar.
| 14 Dec 2010, 13:09 |
christoffer
Vad kostar den i pengar? är du intresserad av en fin fender stratocaster från 79?
| 11 Jan 2011, 16:09 |
[ 2 posts ] |
Users browsing this forum: Bing [Bot] and 31 guests |
