View unanswered posts | View active topics It is currently 23 Sep 2026, 23:03
Reply to topic  [ 19 posts ]
Fan fan fan......
Post Fan fan fan......
Jahapp... det är nog inte meningen att jag skall kunna lira in hemma... Det som började så bra med detta kort, föll platt på slutspurten.... Detta trots hjälp aa två pers, så nu kan jag verkligen skita i detta för all framtid, och förlita mig på de polare som har studios hemma istället... Det verkade ju lovande, men icke sa nicke... samma skit.... Nåväl... detta är ju en säljestråd, så till saken (och ja, jag får lämna tillbaka kortet till butiken, och byta mot ngt annat där, men jag tänkte ge er en chans först...)
<img src="http://www.jam.se/images/speediom.jpg" border=0><img src="http://www.jam.se/images/speediobaks.jpg" border=0>
Highlights:
Separate headphone and line output level controls allowing fast recording / monitoring turnaround
44.1kHz / 48 kHz 16/24 bit simultaneous two channel Audio Input and Output operation with concurrent MIDI Transmission and Reception
Integrated USB bus powered Audio and MIDI - Just a single cable carries Audio and MIDI signals. No need for additional ‘wall wart’ PSU
Continuously variable Monitor control allows for direct hardware zero latency monitoring or low latency software monitoring via the audio application
Two high precision, low noise high bandwidth audio preamplifiers with phantom power and over 70 dB headroom deliver a warm, clear signal typical of Novation's commitment to sonic excellence
Independent Gain controls with LED signal level and overload display. Each channel has separate 20dB boost switches
Independent Phantom power On/Off controls for each channel. - Use Phantom powered
Microphone on one input and Guitar on other!
Very low audio latency - Switchable down to 3mS input and 4mS output with no audio
glitches with fast PC
Runs on Windows XP and MAC OS X Operating systems - driver software included
Supplied with 3 software applications - Novation Live, Cubasis and the classic Novation Bass Station VST for and immediate songwriting / recording
Independent Phantom power On/Off controls for each channel. - Use Phantom powered Microphone on one input and Guitar on other!
Very low audio latency - Switchable down to 3mS input and 4mS output with no audio glitches with fast PC
Nypris 1595:- bytes mot något med strängar.... bas eller gura.... eller något annat om ni kommer med förslag...
<img src="http://www.cmcee.creditmutuel.fr/images/photos_chapitres/stetoscope.jpg" border=0>
Bra covers: http://www.thecoverbox.mine.nu
Bra Iron:http://www.amp-rocks.com
25 Feb 2005, 19:48
jahaja, man kanske skulle köpa....
EDIT: hur var det nu, funkar fantommatningen?
och varf fungerar det inte på din dator?
<img src="http://smilies.f-o-o-l.de/crazy.gif" border=0>The beat goes on and I´m so wrong
Edited by - Joshunznera on 25 February 2005 19:03:47
25 Feb 2005, 20:02
orkar inte dra hela historien om varför det inte funkar, men det har med mitt interna ljudkort att göra igen.... trots att det verkade funka i går...... och nu har jag ju fått hjälp av samma polare som hjälpte mig sist, och han kan verkligen sådana här grejer.... så det är bara att lägga ner projektet...
Fantommatningen verkar funka... man har en knapp för vardera input som växlar över till 48 V fantom...
Du har mail Josh!!
25 Feb 2005, 20:09
Du har mail Josh!!
Men om den funkade igår och din polare som inte grejade det hela förra gången dömer ut den här manicken också... Det kan inte vara så att det är polaren som inte kan det där trots allt?
Mitt tips är ju att du tar med datorn och manicken till JAM. Johan eller Krook kan säkert hjälpa dig. Inte fanken kan det väl vara datorn som det är fel på heller...
25 Feb 2005, 20:17
och du har mailsvar (på din långsamma G-mail....)
25 Feb 2005, 20:18
Nej den verkar vara ganska snabb idag faktiskt.... <img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle> jag har ju skickat tillbaka mail till dig ju....
25 Feb 2005, 20:20
Du har mail Josh!!
Jag hade med mig datorn till JAM igår, och det verkade funka där, men vi provade ju inte så jäkla noga där....
25 Feb 2005, 20:21
Så har BOJen slampan den svarta DeArmond M-65 gått vidare igen då....
Lakka, Bilton, Bjoel, Josh och nu vår nya gitarrsamlare;
the Screwmaster Zakk!
Bra gura det där, du kommer att gilla den!
Edited by - Joshunznera on 25 February 2005 19:35:47
25 Feb 2005, 20:35
Jag vet... har faktiskt ägt en sådan tidigare...
25 Feb 2005, 20:44
Zakk, du har inte funderat på att byta dator istället? <img src=icon_smile_wink.gif border=0 align=middle>
Bra musik: http://www.amp-rocks.com
25 Feb 2005, 22:22
Nope.... jag trivs rätt bra med denna i övrigt... <img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_wink.gif border=0 align=middle>
25 Feb 2005, 22:40
Hur är det den ser ut?
"Did I listen to pop music because I was miserable, or was I miserable because I listen to pop music?"
26 Feb 2005, 02:42
Det är gitarren längst till höger på bilden.... fast detta ex är i kolsvart...
<img src="http://laruetx.com/images/DeArmond_1024.jpg" border=0>
26 Feb 2005, 10:18
Vad heter den tredje guran från vänster? Vad gfår den på...mycket vacker sak!
26 Feb 2005, 17:39
Det är en M75T. Brukar säljas (alltmer sällan) för runt 4000:- Bra gura! (tillverkas inte längre)
26 Feb 2005, 17:58
Sådärja, då har jag också provat denna manick. Skit-pryl! TAskiga drivisar och massor med digitalt noise. Betydligt sämre än M-Audios FAst Track Plus (och dyrare)
Varning utfördas
26 Feb 2005, 17:59
http://www.vendolin.se/annons.php?143352
inte en färg för mig dock
26 Feb 2005, 19:18
Varning utfördas
Du har mail angående detta Josh! Jag visste ju inte att det var ett så dåligt kort, med tanke på att jag inte kunde testa det.... nåja.. hur som helst, så har du ett mail i inboxen i alla fall...
27 Feb 2005, 03:22
Varning utfördas
no probs, jag visste ju att jag hade öppet köp ju. Nu åker kortet tillbaka till Jam och jag köper mig nåt nytt kul där istället. Troligen Fenders nya lilla modelling-stärkare. Julafton hela tiden <img src=icon_smile.gif border=0 align=middle>
Å du, det var nog inte datorn det var fel på, trots allt, det var hårdvaran som var kass. Ett M-audio Fast track kan rekommenderas
27 Feb 2005, 07:51
Users browsing this forum: Bing [Bot] and 29 guests
