[ 9 posts ] |
JBL/Billebro samma tillverkare
Bbenderman
Joined: 13 Feb 2008, 22:19 Posts: 2666 Location: I skogen rönt värmlans trackta
Tror ni en Kines ritade av JBL/EON och tillverkar kopior som kunden får sitt eget namn på. Eller är det samma tillverkare? Jag tror alla lådorna är av samma tillverkare. Här är några ex.
| 03 Jan 2015, 14:17 |
Bbenderman
 Re: JBL/Billebro samma tillverkare
JBL Eon 315 JBL Eon 315 - 15"+2" full range active PA speaker, 2-way bi-amped, 280/560W (RMS/peak), 100º x 60° horn, thomann 1x mic/line input, flat/boost EQ control, 120Hz low cut, 38Hz-20kHz (-10dB), 127dB SPL max, black PVC construction, 36mm pole mount, 5x M10 flying points. Dimensions: 685 x 438 x 366mm. Weight: 15.9kg, optional matching Cover 250821 Billebro Built-in 800W amplifier with crossover 15" Extremely powerful mid-low woofer MP3 playing via USB/SD input Line and mic input with bass & treble controls Daisy chaining of additional speakers High compression dynamic horn driver Wide dispersion horn Stand mounting with 35mm pole socket ABS impact resistant light weight system Supplied per piece Top Hat: Yes Horn: Wide dispersion Driver: High compression dynamic driver Peak power: 800W Frequency response: 40Hz - 18kHz Output power: 400W Dimensions: 350 x 400 x 700mm Weight: 17.0kg Woofer: 15inch SPL max: 126dB
70x35x44cm Pyle 15'' Woofer Compression Driver with 1.75'' Titanium Diaphragm Full Featured 3 Channel Mixer XLR and 1/4'' Mic Inputs XLR & Stereo RCA Line Input XLR and 1/4'' Line Outputs Master Volume, Treble, and Bass Controls Plays MP3s From SD Card / USB Stick 3.5mm Aux-In Compatible With All Digital Music Players, Including iPhone Frequency Response: 30 Hz-22 KHz Power Output: 500 Watts RMS, 1000 Watts Peak Crossover Frequency: 2.2 KHz Integrated 35mm Speaker Stand Mount Dimensions: 19.3'' W x 15.7'' D x 29.1'' H Weight: 58.8 lbs Sold as: Unit Weight: 42.9 lbs.
| 03 Jan 2015, 15:42 |
pudas
Joined: 27 Dec 2007, 16:22 Posts: 3392 Location: växjö
Jag tror att det är designkopiering och troligen gjutet i tunnare och sämre kvalitet, och troligen sämre med inre förstärkningar. Pyle är ju iofs ett gammalt högtalarmärke, men man vet ju aldrig! Har lite svårt att tänka att JBL skulle godkänna att en underleverantör säljer lådorna till andra märken, men åter igen man vet inte!
_________________ pudas
| 03 Jan 2015, 15:51 |
Magnus Olsson
Joined: 09 Dec 2007, 23:13 Posts: 10974 Location: I skogen utanför Göteborg
Troligare att JBL tar fram något som de andra sen kopierar.
Men att samma fabrik bygger till flera märken är ju inget nytt eller ovanligt. Det säger ju ingenting om att det är samma grejer för det, de bygger ju till de specs som märket säger.
/Magnus
| 03 Jan 2015, 15:54 |
Slinky
Haha uselt photoshop-jobb, de har glömt att byta logga i speglingen i nederkant!
| 03 Jan 2015, 16:09 |
Sustain
Man behöver inte titta särskilt noga för att se att lådorna ovan inte är lika, bara liknande. Inbilla dig inte att Billebros grejer är av samma kvalité som JBL och andra etablerade märken, även om de också är tillverkade i Kina. Inte går det att lita på data-uppgifterna heller, det är mest bara ljug. Jag har ett par aktiva Billebro-burkar här för service nu, fick byta ett diskantmembran. Tittar man på hur elektroniken är byggd, så inser man lätt att t.ex. effektuppgifterna är enormt överdrivna. Hur de låter ska man helst inte prata om, de låter fruktansvärt vasst och elakt. Troligen mest p.g.a. ett simpelt delningsfilter. En gammal passiv Behringer-burk som är i sällskap med dem, låter himmelskt i jämförelse. Ungefär samma iakttagelser har jag nyligen gjort med en aktiv lågpris-burk från en annan leverantör. Samma skit ungefär, men den lät rätt bra ändå. Tyvärr gäller i stor utsträckning fortfarande devisen "Man får vad man betalar för". Visst finns det undantag, men räkna inte med att hitta dem hos Billebro. Med det inte sagt att de inte har.
| 05 Jan 2015, 11:10 |
Mike Leaf
Dags för denna tråd igen då..... viewtopic.php?f=4&t=29646
| 05 Jan 2015, 12:13 |
pudas
Jag tror även att det mycket väl kan finnas rena piratkopior på JBL och andra premium märken som florerar på marknaden. Beträffande Behringers "plast" aktiva högtalare har jag goda erfarenheter av dom. Tycker att dom är ett vettigt allternativ, låter OK och står emot att hanteras ute på vägarna.
| 05 Jan 2015, 12:17 |
Mike Leaf
pudas wrote: Jag tror även att det mycket väl kan finnas rena piratkopior på JBL och andra premium märken som florerar på marknaden.
Det finns absolut piratkopior på nästan alla märkesvaror, men det verkar bara vara en del av det som letar sig ut på externa marknader, inom tex Kina finns allt som kopior, gäller ju även alkohol, tobak, mat, reservdelar till bilar, ja i princip allt. De större varumärkena äger ju sin egen design till skillnad från dussinmärken där man kan beställa valfritt namn på produkten.
| 05 Jan 2015, 12:28 |
[ 9 posts ] |
Users browsing this forum: Google [Bot], Obi and 113 guests |
