View unanswered posts | View active topics It is currently 29 Apr 2026, 08:42
Reply to topic  [ 9 posts ]
JBL/Billebro samma tillverkare
Post JBL/Billebro samma tillverkare
Tror ni en Kines ritade av JBL/EON och tillverkar kopior som kunden får sitt eget namn på.
Eller är det samma tillverkare?
Jag tror alla lådorna är av samma tillverkare.
Här är några ex.
03 Jan 2015, 14:17
Post Re: JBL/Billebro samma tillverkare
JBL Eon 315
JBL Eon 315 - 15"+2" full range active PA speaker, 2-way bi-amped, 280/560W (RMS/peak), 100º x 60° horn, thomann 1x mic/line input, flat/boost EQ control, 120Hz low cut, 38Hz-20kHz (-10dB), 127dB SPL max, black PVC construction, 36mm pole mount, 5x M10 flying points. Dimensions: 685 x 438 x 366mm. Weight: 15.9kg, optional matching Cover 250821
Billebro
Built-in 800W amplifier with crossover
15" Extremely powerful mid-low woofer
MP3 playing via USB/SD input
Line and mic input with bass & treble controls
Daisy chaining of additional speakers
High compression dynamic horn driver
Wide dispersion horn
Stand mounting with 35mm pole socket
ABS impact resistant light weight system
Supplied per piece
Top Hat: Yes
Horn: Wide dispersion
Driver: High compression dynamic driver
Peak power: 800W
Frequency response: 40Hz - 18kHz
Output power: 400W
Dimensions: 350 x 400 x 700mm
Weight: 17.0kg
Woofer: 15inch
SPL max: 126dB
70x35x44cm
Pyle
15'' Woofer
Compression Driver with 1.75'' Titanium Diaphragm
Full Featured 3 Channel Mixer
XLR and 1/4'' Mic Inputs
XLR & Stereo RCA Line Input
XLR and 1/4'' Line Outputs
Master Volume, Treble, and Bass Controls
Plays MP3s From SD Card / USB Stick
3.5mm Aux-In Compatible With All Digital Music Players, Including iPhone
Frequency Response: 30 Hz-22 KHz
Power Output: 500 Watts RMS, 1000 Watts Peak
Crossover Frequency: 2.2 KHz
Integrated 35mm Speaker Stand Mount
Dimensions: 19.3'' W x 15.7'' D x 29.1'' H
Weight: 58.8 lbs
Sold as: Unit
Weight: 42.9 lbs.
03 Jan 2015, 15:42
Jag tror att det är designkopiering och troligen gjutet i tunnare och sämre kvalitet, och troligen sämre med inre förstärkningar. Pyle är ju iofs ett gammalt högtalarmärke, men man vet ju aldrig!
Har lite svårt att tänka att JBL skulle godkänna att en underleverantör säljer lådorna till andra märken, men åter igen man vet inte!
pudas
03 Jan 2015, 15:51
Troligare att JBL tar fram något som de andra sen kopierar.
Men att samma fabrik bygger till flera märken är ju inget nytt eller ovanligt.
Det säger ju ingenting om att det är samma grejer för det, de bygger ju till de specs som märket säger.
/Magnus
03 Jan 2015, 15:54
Haha uselt photoshop-jobb, de har glömt att byta logga i speglingen i nederkant! :mrgreen:
03 Jan 2015, 16:09
Man behöver inte titta särskilt noga för att se att lådorna ovan inte är lika, bara liknande.
Inbilla dig inte att Billebros grejer är av samma kvalité som JBL och andra etablerade märken, även om de också är tillverkade i Kina. Inte går det att lita på data-uppgifterna heller, det är mest bara ljug.
Jag har ett par aktiva Billebro-burkar här för service nu, fick byta ett diskantmembran. Tittar man på hur elektroniken är byggd, så inser man lätt att t.ex. effektuppgifterna är enormt överdrivna.
Hur de låter ska man helst inte prata om, de låter fruktansvärt vasst och elakt. Troligen mest p.g.a. ett simpelt delningsfilter. En gammal passiv Behringer-burk som är i sällskap med dem, låter himmelskt i jämförelse.
Ungefär samma iakttagelser har jag nyligen gjort med en aktiv lågpris-burk från en annan leverantör. Samma skit ungefär, men den lät rätt bra ändå.
Tyvärr gäller i stor utsträckning fortfarande devisen "Man får vad man betalar för". Visst finns det undantag, men räkna inte med att hitta dem hos Billebro. Med det inte sagt att de inte har.
/Sixten
http://www.edgaraudio.se
05 Jan 2015, 11:10
Dags för denna tråd igen då.....
viewtopic.php?f=4&t=29646
05 Jan 2015, 12:13
Jag tror även att det mycket väl kan finnas rena piratkopior på JBL och andra premium märken som florerar på marknaden.
Beträffande Behringers "plast" aktiva högtalare har jag goda erfarenheter av dom. Tycker att dom är ett vettigt allternativ, låter OK och står emot att hanteras ute på vägarna.
pudas
05 Jan 2015, 12:17
Det finns absolut piratkopior på nästan alla märkesvaror, men det verkar bara vara en del av det som letar sig ut på externa marknader, inom tex Kina
finns allt som kopior, gäller ju även alkohol, tobak, mat, reservdelar till bilar, ja i princip allt.
De större varumärkena äger ju sin egen design till skillnad från dussinmärken där man kan beställa valfritt namn på produkten.
05 Jan 2015, 12:28
