View unanswered posts | View active topics It is currently 19 Sep 2026, 08:36
Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Perfect el. acoustic **SÅLD**
Post Perfect el. acoustic **SÅLD**
Sucesfully clued spricka on the neckheal
<img src="http://img26.exs.cx/img26/9053/perfectguitar0dh.jpg" border=0>
Perfect el. acoustic.
-Fake painted mahogany back <img src=icon_smile_cool.gif border=0 align=middle>
-Painted fretboard <img src=icon_smile_cool.gif border=0 align=middle>
-EQ-505 + Piezo (original)<img src=icon_smile_cool.gif border=0 align=middle>
PERFECT resegitarr <img src=icon_smile_8ball.gif border=0 align=middle>
BUD!
(Bud över 1000kr accepteras inte)<img src=icon_smile_big.gif border=0 align=middle>
Sounds acousticly very good!
This guitar is fully playable and I have used it on troubadour gigs and I could go and do a gig with it tomorrow, with out a back up guitar.
<img src="http://img224.exs.cx/img224/7372/flaxwoodsmall5ds.jpg" border=0> <font face='Trebuchet MS'> <font size=1>
Minds are like parachutes.
They only function when they are open
http://www.flaxwood.com/</font id='Trebuchet MS'></font id=size1>
Edited by - SoulMan on 28 February 2005 22:10:40
Edited by - SoulMan on 01 March 2005 08:07:00
Edited by - SoulMan on 15 March 2005 11:23:27
Edited by - SoulMan on 19 March 2005 12:16:51
27 Feb 2005, 18:12
Bud: tillbakadraget... <img src=icon_smile_sad.gif border=0 align=middle>
En tjej i bekantskapen har nämligen satt denna summa som gräns för den lägereldsgitarr hon letar efter. <img src=icon_smile.gif border=0 align=middle>
Bra musik: http://www.amp-rocks.com
01 Mar 2005, 20:11
Får nog tyvärr dra tillbaka budet, tjejen kräver nylonsträngar... Sorry.
01 Mar 2005, 22:09
Hade gärna sett att det var en nylonare också...men vart ikring hade du tänkt dig soulman?
"Did I listen to pop music because I was miserable, or was I miserable because I listen to pop music?"
02 Mar 2005, 12:10
Men vaffan, jag börjar på 300:- Under 1000 spänn i allafall. <img src=icon_smile.gif border=0 align=middle>
Place your bids, gentlemen.
02 Mar 2005, 12:20
Det blir ju lite konstigt att låta andra se ens bud, men såhär i början går det ju. Jag har ju rätt skral plånka, och vill en med en elgura i stallet. Men jag gillar formen på denna.
350:-
02 Mar 2005, 13:15
Soulman, du har mail
03 Mar 2005, 19:23
Kom igen kkrans, ge honom ett bud, jag köper av dig den till sommaren!
"Alla Älskar vi Stefan Holm! 2.40!
09 Mar 2005, 17:56
Hehe, väntade på nån respons från SoulMan. Men kan nog gå upp en hundring till men den behöver nog ses och kännas <img src=icon_smile.gif border=0 align=middle>
Det säljs många Landola för 100:- <img src=icon_smile_wink.gif border=0 align=middle>
09 Mar 2005, 19:06
Soulman, vad ska du ha för guran nu då??
<img src="http://smilies.f-o-o-l.de/crazy.gif" border=0>The beat goes on and I´m so wrong
09 Mar 2005, 19:12
Jag blev erbjuden ett paketpris för denna å PMC:n, men flickvännen blev lite sne...annars hade den stått här brevid mig...tror hårt på den där...
09 Mar 2005, 19:32
Bevaknings pris visas ej <img src=icon_smile_wink.gif border=0 align=middle>
<img src="http://img98.exs.cx/img98/6522/takasmall2lw.jpg" border=0> <font face='Trebuchet MS'> <font size=1>
09 Mar 2005, 20:25
vaffaaaaaaaaaa <img src=icon_smile_wink.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle>
501:- bjudet!
09 Mar 2005, 20:51
600
http://kickass.at/pungbuffel<img src="http://www.linkoping.bonet.se/pungbuffel/scrotum.gif" border=0>
14 Mar 2005, 12:27
To add some appetite, mums mums <img src=icon_smile_tongue.gif border=0 align=middle>
<img src="http://img12.exs.cx/img12/8651/mosaic1ah.jpg" border=0><img src="http://img12.exs.cx/img12/6514/perfect2ry.jpg" border=0>
14 Mar 2005, 18:44
Är det en spricka i den?
15 Mar 2005, 02:28
<b>The Perfect Story</b>
I bought this Guitar from Bangok 2001. I did visit about 15 music butiks and this guitar was the best guitar under 2000kr on that day in Bangkok.
The fretboard is fake painted and the back is also fake painted, put I did not mind, because the lock seems to be solid spruce and it has very crispy treble sound when played. There is a very fancy abalone? binding both on the body and on the headstock. It looks like that they could not deside at the factory are they making a high end guitar or a cheapo <img src=icon_smile_big.gif border=0 align=middle>
I did travel a lot and I played this guitar in several countries and finally we ended up to Stockholm.
In the Scandinavian dry winter weather the guitar did "dry" and there came a spricka on the neck heel and the strenghöjd vent up. Also the frets started to stick out, but since there is a binding, you can't feel it when you play it.
I did drill two holes on the spricka and I did inject clue inside the spricka and I did put it under pressure.
Result>
<b>Spricka seems to be now solid</b> and the stringhöjd can be adjusted to very low if you want to.
The fretboard is not fully straight at the 12th fret, but it don't effect too much for the playability. If you are good to meka, you can slipa the fret board and fix the frets and you have a beautiful guitar which sounds very good and is nice to play.
The guitar is fully playable and it sounds very good as it is now. (komer med påsse)
<font size=1>(I did not paint the spricka so you can see what has been done with the guitar)</font id=size1>
<img src="http://img202.exs.cx/img202/2619/spricka2rc.jpg" border=0>
<img src="http://img110.exs.cx/img110/9900/oiledrock8ld.jpg" border=0> <font face='Trebuchet MS'> <font size=1>
Edited by - SoulMan on 15 March 2005 08:14:38
15 Mar 2005, 09:09
Hur går det då?
Blir det någon gitarr eller?
15 Mar 2005, 09:48
Det är lite svårt att skicka... ingen case
Edited by - SoulMan on 15 March 2005 10:00:49
15 Mar 2005, 10:59
Ok, så jag vet inte om jag får gitarren ens om jag vinner budgivningen menar du?
15 Mar 2005, 11:19
Nej, Om du vinner du vinner
Men om du bor inte i Stockholm, det är jätte svårt at packa up en akustisk gitarr,
och Du vill inte att jag ska skicka den i gig bag. (och frakt tillkommer)
15 Mar 2005, 11:59
Ok, tycker bara att det är ett skumt sätt att sköta en budgivning, svårt att ge motbud på ett icke existerande bud.
15 Mar 2005, 12:12
700
15 Mar 2005, 12:23
Tack, 750.
15 Mar 2005, 12:52
Fan, jag skulle ha slagit till på priset du erbjöd mig soulman =)
15 Mar 2005, 15:37
Paket pris för two gitarrer är en annan sak.
Om du köper en Flaxwood komer den här på köpet <img src=icon_smile_big.gif border=0 align=middle>
15 Mar 2005, 18:22
Inte tvärtom då??
<img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle>
15 Mar 2005, 18:26
Tack, 750.
Du har mail <img src=icon_smile.gif border=0 align=middle>
15 Mar 2005, 23:15
Tack, 750.
Du med.<img src=icon_smile.gif border=0 align=middle>
16 Mar 2005, 08:11
<img src="http://img237.exs.cx/img237/6397/pict30149kr.jpg" border=0> <img src=icon_smile_cool.gif border=0 align=middle>
21 Mar 2005, 14:45
Users browsing this forum: No registered users and 46 guests
