View unanswered posts | View active topics It is currently 23 Sep 2026, 15:14
Reply to topic  [ 8 posts ]
såld
Post såld
Det är en sådan handbyggd Canada hals ny.
25 1/2 inch scale length.
Width at Corian nut: 1 3/4 inches Heel is 2 3/16ths
Profile is"C": .860 at first fret and .960 at the 12th with 21 Medium Jumbo Frets
Headstock has a 13 degree tilt. No string tees needed.
Ebony markers on a 12" radius fretboard
Drilled for 10mm tuners or 11/32.
Hand Polished Nitro finish overall.
Vintage Aluminum truss rod with heel adjustment
Prylgalen
14 May 2008, 11:25
Någon som är intresserad 1600kr
Prylgalen
15 May 2008, 10:28
Är det en one-piece, eller är fretten limmad på själva halsen?
[:o)]
<font color="green">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="green">
17 May 2008, 21:00
Buda
Prylgalen
20 May 2008, 00:18
Är det strat eller tele-heel?
Svårt att se på bilderna.
Ser nästan ut som ngt mittemellan.
20 May 2008, 11:51
Vet inte
Men har haft den på en standard tele.
Prylgalen
21 May 2008, 00:08
Sänker priset till 1000kr[:0]
Prylgalen
31 May 2008, 19:03
Users browsing this forum: No registered users and 46 guests
