View unanswered posts | View active topics It is currently 20 Nov 2026, 02:50
Reply to topic  [ 8 posts ]
HUR spelar jag upp ed .cda-fil??
Post HUR spelar jag upp ed .cda-fil??
går detta över huvud taget? Är det inte så att dessa filer bara kans spelas av från en CD?
Jag har ett par cda-file som jag behöver lyssna på men vet inte hur
Någon?
05 Aug 2007, 22:18
Det första svaret jag kommer på är: Det beror på.
Men det här kanske hjälper dig mer:
Why can't I play CDA files?
The .cda (CD Audio Track) file isn't registered to be opened by Windows Media Player. You can register the Player to play CDA files by doing the following:
1.
In Control Panel, open Folder Options.
2.
In the Folder Options dialog box, click the File Types tab.
3.
In the Registered file types list, scroll down to the CDA extension to see which program is registered to open the file type. The associated program, shown in the following Details for 'CDA' extension area, should open whenever you place a CD in your CD drive or when you double-click a CDA file. If no program is displayed, register the Player by completing this procedure.
4.
In the Details for 'CDA' extension area, click the Change button.
5.
In the Open With dialog box, select Windows Media Player as the program that you want to use to open CDA files.
6.
Make sure that the Always use the selected program to open this kind of file check box is selected.
Note that the actual music tracks on a CD are usually WAV files that you can't see; the CDA files on a CD act as a table of contents for software that "point" to these hidden music tracks. If the Player is registered to open CDA files, but you still can't play the CD, the CD may not have been created using CD-burning software (that is, the CDA files, but not the music files, were copied to the CD).
05 Aug 2007, 22:24
hmm, jag hade redan kollat det där (sökte på samma sätt[:)]) men det funkade inte
05 Aug 2007, 22:32
Ah! Kan det vara så att dina .cda-filer inte innehåller någon ljudinformation alls?
Har du kollat hur stora de är?
A CD Audio Track or .cda file is a small (44 bytes) file generated by Microsoft Windows for each track on an audio CD. The file contains indexing information that programs can use to play or rip the disc. The files are given names in the format Track??.cda.
The .cda files do not contain the actual PCM wave data, but instead tell where on the disc the track starts and stops. If the file is copied from the CD-ROM to the computer, it becomes useless, since it is only a shortcut to part of the disc. However, some audio editing and CD creation programs will, from the user's perspective, load .cda files as though they are actual audio data files.
05 Aug 2007, 22:37
fixat!
fast via genväg.. (polarn rippade till MP3 och skickade via Yousendit istället[:)])
05 Aug 2007, 22:38
Joshunznera wrote:
fixat!
Ah :)
Men kolla storleken på dina .cda-filer bara för min skull :)
05 Aug 2007, 22:40
jo det var det som var felet, en polare som kan ännu mindre om cda än jag själv tydligen
Men tack ändå[:)]
05 Aug 2007, 22:40
Men tack ändå[:)]
Ingen orsak.
05 Aug 2007, 22:44
