View unanswered posts | View active topics It is currently 09 May 2026, 06:23
Tips på bra overdrive (oops fel forum)
Post Tips på bra overdrive (oops fel forum)
Typ "Yngwies" DOD preamp overdrive fast bättre och med mindre brus.
27 Jun 2008, 11:01
Är detta off-topic??? [;)]
<font color="green">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="green">
27 Jun 2008, 12:14
Men ursäkta då!!!!!!!!
27 Jun 2008, 12:51
"Bojpolisen" har slagit till igen! [8D]
27 Jun 2008, 13:39
