| TV1 nu! https://ljudbojen.com/viewtopic.php?f=4&t=19008 |
Page 1 of 1 |
| Author: | FenderBender [ 02 Sep 2008, 21:23 ] |
| Post subject: | |
Tusan att jag missade det! Får spetsa in mig på reprisen... Var det The Who i ett helt program eller bara en "blink"? [:)] <font color="green"><font size="1">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="size1"></font id="green">
| Author: | Renegade [ 02 Sep 2008, 23:25 ] |
| Post subject: | |
Missade det och missade att spela in det.[B)] Har ställt in DVDn att spela in reprisen. /R <img src="http://i14.photobucket.com/albums/a308/torn_and_frayed/red-tonguesmaller.gif" border=0> "Art is the last thing I'm worried about when I'm writing a song. As far as I'm concerned, art is just short for 'Arthur'." - Keith Richards |
| Author: | Fotogeno [ 03 Sep 2008, 09:24 ] |
| Post subject: | |
Har man lite tur så kan man se programmet igen på http://www.svt.se[:)] Bo-Conny Skruvlin |
| Author: | FenderBender [ 03 Sep 2008, 09:30 ] |
| Post subject: | |
Jag hade programmerat min HD på inspelning av programmet och glömt det[:)]! Det var en väldigt trevlig beskrivning av The Who faktiskt. Hade ingen aning om att de började som ett "tönt-pop" band! [}:)] <font color="green"><font size="1">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="size1"></font id="green">
