[ 16 posts ] |
mrcheese
 Trimmtips Strata
Saxat från GMF-planket Posted - 15 Dec 2003 : 23:47:54 -------------------------------------------------------------------------------- http://www.voodoopickups.com/install.htm[/quote] Tack för tipset twreck , intressant ska testas snarast. Mvh RICKY http://www.bostream.nu/mrcheese/http://medlem.spray.se/guitarmaniac/mrcheesedodle@hotmail.com[/quote] Ja nu har det testats och jag har justerat alla mina strator och telen enl tipset. Kan bara hålla med om att det är mycket nära idelmåtten jag hamnade på +/- 0,5mm beroende på vilken gitarr/mickar. Mindre sura toner på låga E högre upp , bättre sustain och alla mickarna matchar varann bättre i nivå/balans när man "fasat" in dom i egglägena. Jag kommer absolut använda mig av dessa mått som grovjustering och träna mig att "lyssna" fram bästa resultat. Här är tillvägagångssättet igen (även i mm) Install the pickup's -Solder the connections -Raise the bridge pickup to" 1/8 (3,2mm) from the high "E" string -Raise the Bridge pickup side to" 1/4 (6,3mm) from the low "E" string -Place the selector switch in the 2nd position (or between the bridge and middle position) -Raise the middle pickup to" 3/16 (4,7mm) from the high "E" string -Raise the middle pickup to" 1/4 (6,3mm) from the low "E" string -Now adjust the low "E" side of the middle pickup while playing a little, try to get the most "quack" and phase in the sound. You may have to lower and raise both the bridge pickup and the middle pickup(on the bass side) until you can get a tone that is really " quacky". -Now place the position switch in the 4th position between the middle and the neck position -Raise the high "E" side to about 3/16 (4,7mm) from the string , -Now adjust the low "E" side while you are playing, try to get the most out of phase "Quacky " sound you can get. You may have to adjust and tweak the treble side and the bass side's of the other pickups. -When you have the 2 and 4 position sounding the way you want , you should have the guitar voiced so that all the positions have a distinctive sound. Tele's Tele set ups: -Install pickups -Solder connections (this is for a wiring pattern that uses both pickups in the middle position , not for early Tele wiring) -Raise the bridge pickup to 3/16 (4,7mm) on the high "E" side -Raise the bridge pickup to 1/4 (6,3mm) on the low "E" side -Place the selector switch in the middle position -Adjust the neck pickup height until you can a distinct blend of the pickups -Now check the sound on all three positions and they should be 3 distinct sounds with character. 1/8" = 3,17mm 3/16"= 4,76mm 1/4" = 6,35mm Mvh RICKY http://www.bostream.nu/mrcheese/http://medlem.spray.se/guitarmaniac/mrcheesedodle@hotmail.com
| 16 Dec 2003, 00:52 |
kkrans
Joined: 13 Mar 2003, 00:26 Posts: 2693 Location: Solna, Sweden
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> -Now adjust the low "E" side of the middle pickup while playing a little, try to get the most "quack" and phase in the sound. You may have to lower and raise both the bridge pickup and the middle pickup(on the bass side) until you can get a tone that is really " quacky". ************** -Raise the high "E" side to about 3/16 (4,7mm) from the string , -Now adjust the low "E" side while you are playing, try to get the most out of phase "Quacky " sound you can get. You may have to adjust and tweak the treble side and the bass side's of the other pickups. dodle@hotmail.com<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Intressant tech-snack, men vad uppnår man om man gör detta?!? <img src=icon_smile_blush.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle>
| 16 Dec 2003, 01:44 |
mrcheese
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> -Now adjust the low "E" side of the middle pickup while playing a little, try to get the most "quack" and phase in the sound. You may have to lower and raise both the bridge pickup and the middle pickup(on the bass side) until you can get a tone that is really " quacky". ************** -Raise the high "E" side to about 3/16 (4,7mm) from the string , -Now adjust the low "E" side while you are playing, try to get the most out of phase "Quacky " sound you can get. You may have to adjust and tweak the treble side and the bass side's of the other pickups. dodle@hotmail.com<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Intressant tech-snack, men vad uppnår man om man gör detta?!? <img src=icon_smile_blush.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle> <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Är det "quacky" du menar? , det handlar om att justera dina singlecoil mickar optimalt så även egglägena låter bra. Det är inte så svårt att justera mickarna att låta bra var och en för sig men att få en bra balans/ljud mellan stall/mitt och mitt/hals är svårare . En annan sak är att man ofta justerar upp mickarna alldeles för nära strängarna med en del nackdelar som följd. Mickarnas magnetism håller fast strängarna och du får sämre sustain, de spunna strängarna kan låta lite surt en bit upp på halsen. Förstärkningsförlusten kan man ju justera/kompensera i andra änden där man pluggat in kabeln<img src=icon_smile_wink.gif border=0 align=middle> Mvh RICKY http://www.bostream.nu/mrcheese/http://medlem.spray.se/guitarmaniac/mrcheesedodle@hotmail.com
| 16 Dec 2003, 22:53 |
kkrans
Ok, intressant... ska testa detta med min 3xSC Roadstar som låter inte så bra i mellanlägen <img src=icon_smile.gif border=0 align=middle>
Då undrar också man om detta går att använda med en Strat som har SSH?
| 17 Dec 2003, 00:57 |
BlackStrat
Tackar för tipset!<img src=icon_smile.gif border=0 align=middle>
Nu låter halsläget på stratan ännu bättre och läge 4 blev riktigt bra.<img src=icon_smile_tongue.gif border=0 align=middle>
Nu kom verkligen Lundgren mickarna till sin rätt!
/BlackStrat
| 17 Dec 2003, 01:49 |
mrcheese
Humbucker har inte lika hårt "strängdrag" så de kan (om man vill) justeras närmare strängarna utan att hämma ton/sustain. Jag upplever att Lundgrens mickar har ganska starka magneter och mår lite bättre av att justeras enl ovan. Mvh RICKY http://www.bostream.nu/mrcheese/http://medlem.spray.se/guitarmaniac/mrcheesedodle@hotmail.com
| 17 Dec 2003, 10:17 |
BlackStrat
Jo, Lundgrens mickar har starka magneter men nu låter det kanon! <img src=icon_smile_big.gif border=0 align=middle>
Jag är väldigt nöjd med just dessa mickar och har svårt att tänka mig nåt annat. Nu skulle man bara bli klar att justera in stratan för 11-50 strängar i stället för 10-46 som jag kör nu, är liksom lite väl mycket "spagetti" över det och bending går lite väl lätt.
/BlackStrat
| 17 Dec 2003, 20:12 |
Bilton
Joined: 12 Aug 2002, 11:26 Posts: 4579 Location: Västra Mälardalen
Jag provade detta efter att ha installerat nya mickar i den nyligen införskaffade stratan.
Det låter nästan som en parodi på strata - alltså utpräglat tydlig skillnad på alla lägen. Jag utgick från de nominella värdena och justerade ingenting, jag bara mätte avståndet och det funkade mycket bra. (Jag funderade lite på om det skulle vara avståndet från mickkåpan eller magneten och konstaterade att jag har "staggade" magnetpoler och gjorde det enkelt för mig. Jag mätte från kåpan som blir ett slags medel. Funkar skitbra!)
Jag installerade dessutom en treble bleed av Kinmans modell - den gillade jag inte. Jag skall återgå till det vanliga, en konding parallelt med en resistor över poten vilket jag tycker funkar bättre, släpper igenom lika mycket diskant hela tiden och är mer linjär!
/Bilton "Arbete främjar hälsa och välstånd och förhindrar många tillfällen till synd!" -Martin Luther
| 21 Dec 2003, 23:36 |
mrcheese
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Jag provade detta efter att ha installerat nya mickar i den nyligen införskaffade stratan. Det låter nästan som en parodi på strata - alltså utpräglat tydlig skillnad på alla lägen. Jag utgick från de nominella värdena och justerade ingenting, jag bara mätte avståndet och det funkade mycket bra. (Jag funderade lite på om det skulle vara avståndet från mickkåpan eller magneten och konstaterade att jag har "staggade" magnetpoler och gjorde det enkelt för mig. Jag mätte från kåpan som blir ett slags medel. Funkar skitbra!) Jag installerade dessutom en treble bleed av Kinmans modell - den gillade jag inte. Jag skall återgå till det vanliga, en konding parallelt med en resistor över poten vilket jag tycker funkar bättre, släpper igenom lika mycket diskant hela tiden och är mer linjär! /Bilton "Arbete främjar hälsa och välstånd och förhindrar många tillfällen till synd!" -Martin Luther <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Kul att det funkar<img src=icon_smile.gif border=0 align=middle> Det sparar en massa tid med dessa "grundinställningar" har justerat 4 av mina strator och min tele enl ovan. Testade också Kinman-kopplingen på min tele , tycker att den funkar ok men inte lika jämn/linjär avrullning av volymen. Får väl testa på strata också även om jag har 3 mickar på telen. Mvh RICKY http://www.bostream.nu/mrcheese/http://medlem.spray.se/guitarmaniac/mrcheesedodle@hotmail.com
| 22 Dec 2003, 00:10 |
matt
Har på min strata låtit löda in ett motstånd på volymkotrollen så att den funkar lite som på en tele, att den släpper igenom diskant när jag drar ner volymen.
Detta fungerar bra då det har en tendens att bli lite dovt när man drar av volym med std kopplingen och så kan jag dra in halsmicken om jag har stallmicken igång och den modden har varit uppe förr men den kan ändå få påminnas lite frann så här i juletider.
| 22 Dec 2003, 09:49 |
Din_Mentor
Rör om lite i en tokgammal tråd! tänkte mig finjustera mickarna på min strata med CS'69 mickar och denna tråden verkade innehålla bra tips för mickhöjdsjustering [:)]
sitter här o försöker få till nåtslags quack ljud på mitt-stall kombinationen, men jag finner det svårt att få till! har mätt upp exakt så som angivit och experimenterat med höja sänka mitt micken på bas sidan. nåt jag missar? har skruvat ner mitt micken ett kvarts varv åt gången tills den ligger i kant med plektrumskyddet men ändå får jag ingen AHA-upplevelse... [:(][:D][:p] hilfe?
EDIT1: vad är det ultimata quack testet? kör genom en peavey classic 30 på rena kanalen med lite reverb bara... gärna nåt simpelt! [8)][;)]
EDIT2:I steget där man ställt in mitt och stall micken och sedan skall justera in quacket, ska man då justera de parallelt upp eller ner? alltså höjer jag mittmicken 1mm så gör jag detsamma med stallmicken?
-Lots of towns... Lots of songs... Lots of women... Good times... Bad times...-
| 03 Jun 2011, 21:57 |
Lemmy
Joined: 10 Mar 2004, 23:38 Posts: 2344 Location: Gislaved SWISH
Wow, detta måste väl va nån sorts rekord i lyft av gammal tråd [:)] I alla fall kul tips som måste testas  Si fractum non sit, noli id reficere
| 03 Jun 2011, 22:43 |
Din_Mentor
Lemmy wrote: Wow, detta måste väl va nån sorts rekord i lyft av gammal tråd [:)] I alla fall kul tips som måste testas  Si fractum non sit, noli id reficere Joo i guess, haha ring guiness! [8D] men kändes bättre att samla all info på samma ställe? om inte så my bad [:D] nån expert på mickinställnigar som kan svara? [:p] -Lots of towns... Lots of songs... Lots of women... Good times... Bad times...-
| 03 Jun 2011, 23:04 |
PGW
Grattis till världsrekordsförsöket![:D]
Intressant att de rekommenderar relativt låg mickhöjd med tanke på den allmänna åsikten att mickarna ska upp så nära mickarna som möjligt.
Nej, du inte skruva upp bägge mickarna - (ursäkta om det blir surrigt, lite trött nu[:I]) kvacket uppstår av fasfelet mellan signalerna som mickarna skickar ut, du ska alltså justera stallmicken först & sedan justera in mittmicken utifrån hur de låter tillsammans. Fungerar det som det ska hör du skillnad på hur kvackigt ljudet med mittmicken i olika höjdlägen, när du är nöjd justerar du halsmicken i förhållande till mittmicken enligt samma metod.
[url="http://roaddust.zoka.cc/index.html"]<font color="red">High Octane Rock´n´roll</font id="red">[/url]
You shouldn´t call the doctor if you can´t afford the bills!" - Wilko Johnson
| 06 Jun 2011, 05:56 |
Din_Mentor
PGW wrote: Grattis till världsrekordsförsöket![:D]
Danke schön! Får bli att experimentera mer nån kväll när verktygslådan är framme [:p][:D] -Lots of towns... Lots of songs... Lots of women... Good times... Bad times...-
| 06 Jun 2011, 10:47 |
PGW
PGW wrote: Intressant att de rekommenderar relativt låg mickhöjd med tanke på den allmänna åsikten att mickarna ska upp så nära <font color="red">mickarna </font id="red"> som möjligt.
Menar förstås <font color="red">strängarna </font id="red"> .... [url="http://roaddust.zoka.cc/index.html"]<font color="red">High Octane Rock´n´roll</font id="red">[/url] You shouldn´t call the doctor if you can´t afford the bills!" - Wilko Johnson
| 07 Jun 2011, 02:42 |
[ 16 posts ] |
Users browsing this forum: Marshall, TUF and 13 guests |
