Lite spännande grejer som händer hos våra grannar i Finland...
Här egen recension från tillverkaren...
- Hand made point to point wired 40-75W tube amp that is fine-tuned for the best possible tone.
- Based on the experience Bjorn Juhl has had working with tubes amps for 20 years.
- The circuit is as original as a tube amp can be, respecting the heritage of the greatest amps designs.
<img src="http://www.custom-sounds.com/kuvat/madpro.gif" border=0>
- Preamp distortion and/or Power-amp distortion, with or without compression at any volume level.
- Three (3) gain structure options.
- Versatile Focus and Nature switches
- Five (5) different ways to adjust the ever critical treble response.
- Effect loop with two different levels.
- Foot-switch for adjustable Boost
- Dynamics you have never experienced.
- Best workmanship in the industry.
- Magical Bjorn Juhl circuit.
- THE TONE!!
<img src="http://www.custom-sounds.com/kuvat/mp_circuit3.jpg" border=0>
We are not talking about 3-dimensional tone, this one is a 4-D tone!
And the touch response is awesome, this is about the most dynamic amp I have seen.
There are tones from sparkling clean to fat and sweet, singing overdrive, from sparkle to rumble...
- The finetuned circuit with build in bias adjustment accepts 6L6, EL34, KT66, KT88 ... even 6V6 if you can find ones that can handle 500V of plate voltage.
- The overbuild custom transformers have enough juice to drive the KT88/6550 to almost 100W of power.
- With special POWERSUCK switch you can drive the power-amp to fat compressed tone at bedroom levels
Nothing but the best covering is used, no thin tolex here.
ALL the parts are overrated and should last for ages.
The amp is already available by custom order and it can be played all over the world (100/117/230/240V)
VISITING STOCKHOLM!!!
AT STOCKHOLM GUITAR SHOW 2002 (nån som var där o såg dem ??)
<img src="http://www.custom-sounds.com/kuvat/stockholm_mp_olli.jpg" border=0>
mmm det här måste man bevaka...
Ok! priset kan va lite avskräckande...
Head 5200 €
Cabinet 1250 €
Hand-Made u know...
Slowhand2
Peace - Love & LeftHanded Guitars
<img src="http://www.swedenblue.com/bilder/swedenblue-logg3.jpg" border=0>
http://www.swedenblue.comEdited by - Slowhand2 on 05 April 2003 12:41:13
Edited by - Slowhand2 on 05 April 2003 14:00:12
