View unanswered posts | View active topics It is currently 16 Sep 2026, 05:51
Reply to topic  [ 5 posts ]
Kan man mäta resistans för att se hur "hot" ett CM/CR är?
Post Kan man mäta resistans för att se hur "hot" ett CM/CR är?
Jag har hört olika åsikter om det. Eller är enda sättet att använda öronen?
http://greenbulletmics.com står det:
Another thing that I've heard people say is that the higher the resistance reading is, the more gain, or hotter the element will be. This is nonsense! Differences in resistance of the windings is not going to determine how hot an element will be. At least not at differences as small as 100 or so ohms on a high Z controlled magnetic element as used in today’s applications. Yes, a low Z CM element will not have the gain of a high Z element, but the difference in resistance is much larger, and they're usually plugging them into a guitar amp that has 1 meg or higher input impedance. While it is true with certain microphones, a small difference in resistance with CR and CM elements is not going to make an element stronger or weaker than another. I have had CR's close to 1,400 ohms that weren't any stronger than CM's that were 1050 ohms. In fact, I've had some lower resistance elements that were much hotter than elements of higher resistances. There are many things that determine how much gain these elements have. Slight differences in resistance is not one of them.
There are many things that can affect how well an element of this type performs. I can't get into everything, but the main ones are magnet strength, armature alignment, diaphragm condition, debris getting into the magnetic assembly, crud collecting on the diaphram and corrosion build up.
Håkan
29 Aug 2012, 22:45
Post Re: Kan man mäta resistans för att se hur "hot" ett CM/CR är
Brukar mäta upp impedansen, för att ha nåt att jämföra med när jag provspelar och lyssnar. Men jag har inte blivit klokare. För elementen verkar leva ett eget liv så att säga. Högre impedans behöver inte innebära att elementet låter bätttre. :)
Blow On!
30 Aug 2012, 17:23
Tack Robert!
Jag fick liknande svar på Dirty Blues Harp Forum. Så då får man väl köra på det.
Håkan
31 Aug 2012, 03:56
Resistansen säger ingenting annat än att spolen är hel och om mikrofonen är av hög eller låg ohms modell.
Miken kan tom vara död utan att det syns på resistansen.
Det är andra saker som avgör. Hur lätt membranet rör sig, hur långt det rör sig, m.m.
Jag har ett mediumimpedans (350 ohm ca) shure element som ger en lika volymstark signal som ett hyfsat CM.
Se upp för element som ser mycket fläckiga och angripna ut.
Ligger det ett lager med vit avlagringar på elementet har det förvarats fuktigt och då kan membranet kärva i spolen.
Bucklor kan betyda att det är tappat och samma sak där. då kan membranet ha flyttats ur läge och kärva.
Vad skiljer elementen åt frågar man sig då som god vän av ordning :wink: :wink:
Gamla svarta element har annan tjocklek på kopparen i spolen. Koppartrådens metallsammansättning är inte exakt som de nyare. Numera är den troligtvis uppblandad för att bli billigare.
Membranets hävstång till den rörliga spolen fästs in med en aluminiumbricka på de gamla reluctance elementen. De är limmade på de nyare. osv.. osv...
31 Aug 2012, 09:46
Tack för ditt klargörande Arne!
Håkan
31 Aug 2012, 14:53
Users browsing this forum: Majestic-12 [Bot] and 2 guests
