| Gibson vintage och uppgraderingsdelar Callaham, Guitarworks https://ljudbojen.com/viewtopic.php?f=26&t=72527 |
Page 1 of 1 |
| Author: | gibsonclassic2001 [ 09 May 2012, 17:21 ] |
| Post subject: | Gibson vintage och uppgraderingsdelar Callaham, Guitarworks |
Har rensat min Historic makeover Gibson reissue 1959 på dessa delar. 30-50% avdraget på alla nypriser! Enbart bästa bitarna från OTP vintage heaven, Callaham, Guitarworks, Rod Kinkade, Faber, Montreux och blandade leverantörer i USA mm. Kan göra bra paketpris vid större affärer. OTP vintage heaven pickup rings (bone white) 1200:- (nypris 2300:-!!!!!) OTP vintage heaven tuners 660:- or Aged grovers 350:- Lightly aged Callaham ABR-1 800:- (nypris 1550:-!!!!) Lightly aged Thin 59 replica thumb wheels SS- ABR-1 bolts Lightly aged 59 replica tailpiece 700:- (nypris 1300:-) Lightly aged Steel inserts 150:- Lightly aged Steel studs (tone lock) Vintage un-bleached bone nut 100:- Low output PAF replica pickups 1900:- (nypris 3000:-) Lightly aged 59 replica covers and pickup screws 400:- Lightly aged Pick guard and bracket 450:- (nypris 765:-) Lightly aged 59 replica switch tip 100:- Lightly aged 59 replica knurled switch ring 70:- (nypris 110:-) Lightly aged 59 replica toggle ring 200:- (nypris 295:-) Lightly aged 59 replica jack plate 200:- (nypris 315:-) Lightly aged 59 replica ton/volymkontroll 200:- (nypris 300:-) Lightly aged 59 replica rolled cover till dragstången. 300:- (nypris 600:-) Jensen PIO´s .047, .033, .022, .015, .010 70:- styck (nypris 175:- styck) Nås på 073-6899875 |
| Author: | Britbender [ 09 May 2012, 19:02 ] |
| Post subject: | Re: Gibson vintage och uppgraderingsdelar Callaham, Guitarwo |
Köper gärna din "Vintage un-bleached bone nut" |
| Author: | Rockley [ 10 May 2012, 00:00 ] |
dubbelpost. |
| Author: | Rockley [ 10 May 2012, 00:01 ] |
Hej! Jag vill köpa några grejer men jag vill reda ut några saker först så skulle vilja ha första tjing tills det är utrett! 1. Lightly aged Thin 59 replica thumb wheels. Här har du inte uppgett något pris, vad ska du ha? Är dessa köpta från Retro Spec eller vad de heter? Isåfall, följer original-stolparna med då? (som är nickelpläterad mässing) 2. Vad är det för plektrumskydd? Märke? Till vilka historics passar dom? Dom flyttade väl runt mickarna nån gång på 2000-talet tror jag bestämt. Mvh / Erik |
| Author: | gibsonclassic2001 [ 10 May 2012, 07:23 ] |
![]() Verkar vara 3 versioner på plektrumskydd. Dock så bör december 1998 till december 2008 ha samma som måttet på mitt. |
| Author: | gibsonclassic2001 [ 10 May 2012, 07:25 ] |
Britbender wrote: Köper gärna din "Vintage un-bleached bone nut" Hej! Vad har du för "frets"? Denna passar enbart med Historic/VOS och lägre. Dvs. ej USA jumbo mfl |
| Author: | Britbender [ 10 May 2012, 17:08 ] |
Tanken var att ha den på en Heritage H150, som enligt nätet har- 1 11/16" nut width and a 12" fingerboard radius. en vild chansning alltså !!!;) |
| Author: | gibsonclassic2001 [ 10 May 2012, 18:51 ] |
Britbender wrote: Tanken var att ha den på en Heritage H150, som enligt nätet har- 1 11/16" nut width and a 12" fingerboard radius. en vild chansning alltså !!!;) Ok, kan fungera! Kan skicka imorgon. Kontakta mig via PM så löser vi det |
| Author: | gibsonclassic2001 [ 14 Jul 2012, 16:14 ] |
bump! |
| Author: | johanPetter [ 30 Aug 2012, 16:25 ] |
PM! |
| Author: | gibsonclassic2001 [ 10 Jan 2013, 00:07 ] |
Bump Har dubbelt av allt igen. Hjälp mig rensa lådorna. |
| Author: | nilo [ 10 Jan 2013, 10:28 ] |
Plektrumskyddet, har det rätt färg och inte är rosa-aktigt eller för orange så kan du skicka PM till mig. Eller gör det iaf så får du min mail och kan skicka bilder |
