https://ljudbojen.com/
*SÅLD* Yamaha 02R96 Digital Mixing Console, Version 2
https://ljudbojen.com/viewtopic.php?f=26&t=127491
Author:  P_Nilsson [ 24 Feb 2021, 09:52 ]
Post subject:  *SÅLD* Yamaha 02R96 Digital Mixing Console, Version 2
Säljer min Yamaha 02R96 Digital Mixing Console, Version 2.
56-input 18-bus Mix Capacity at 96 kHz
Utrustad med mätarbrygga MB02R96 samt 2st MY16-AT kort. 16 in/out per kort. Totalt 32 in/out.
DAW control. Protools, Cubase etc.
Finns i Göteborg.
Nerplockad just nu men går givetvis att starta upp och kolla, Allt funkar, inget skrap eller dylikt. Lite trött i reglarna då den stått still ett tag men lite motion så rör sig reglarna fint.
Intressanta delbyten/byten tex. Lexicon PCM 70, 81. Korg DL 8000r Delay. Fender Strata, Telecaster, Custom Audio Electronics midi pedalbord eller annat kul från CAE.
Pris: 9500:-
Mvh Peter
Specifikation:
Mixing channels: 56 , 24 Touch-sensitive 100-mm Motor Faders
Group channels: 8
AUX Channels: 8
Input channel functions: Gate, Attenuator, 4-band PEQ, 2x Compressor, Delay, Pan
Output channel functions: Attenuator, 4-band PEQ, Compressor, Delay
On-board Effect processors: 4x SPX multi effectors
Mic inputs: 16
Phantom power: +48V DC; ON/OFF per channel
Line inputs: 4x Stereo, 2x 2tr in
AD converter: 24-bit; 128-time over sampling
Line outputs: Stereo output, Studio monitor output, C-R monitor output, 8x Omni output
DA converter: 24-bit; 128-time over sampling
Digital I/O: 3x 2tr in/out, Cascade I/O
Expansion slots: 4x Mini-YGDAI (16-in/16-out)
Control and others: To Host(USB/Serial), Control(GPI), MIDI, Time code in (SMPTE/MTC), Word clock I/O
Dimensions
W 667mm
H 239mm
D 697mm
Weight: 34kg
