View unanswered posts | View active topics It is currently 15 Nov 2026, 01:08
DiMarzio Humbucker from Hell DP156
Post DiMarzio Humbucker from Hell DP156
Fyrtåtad, funkar prima!
Namnet är väldigt missvisande, låter väldigt mycket single coil i humbuckerformat.
500 SEK, finns i Stockholm och kan självklart skickas.
Enligt DiMarzio:
Because a conventional humbucker senses the string at two different places, it cancels some frequencies along with the hum. What if there was a humbucker that cancelled fewer frequencies? It would be brighter and cleaner: almost glassy-sounding. In other words, it would sound a lot like a Strat® pickup, but with about the same power as a PAF®. We created The Humbucker From Hell® primarily as a neck pickup. You won’t believe how much it will open up the sound in the neck position of a Gibson® Les Paul®, and it has an almost acoustic quality in the neck spot of a bolt-on guitar. Why is it called The Humbucker From Hell®? Try it in the bridge position with a bright amp — but put in your earplugs first, and don’t say you weren’t warned.
13 Apr 2020, 20:32
Post Re: DiMarzio Humbucker from Hell DP156
Färg...?
Spacing...?
/ Jonken :?:
14 Apr 2020, 12:12
Jonken wrote:
Färg...?
Spacing...?
/ Jonken :?:
Creme, alltså snyggt gulnad.
Osäker på spacing men den i halsposition linjerar den perfekt med Floyd-stall. Och det är primärt där den hör hemma.
14 Apr 2020, 13:56
Finns den kvar?
23 Jun 2020, 18:55
