View unanswered posts | View active topics It is currently 23 Nov 2026, 23:04
INFINIUM Valve Life Multiplier Technology?
Post INFINIUM Valve Life Multiplier Technology?
Såg på Bugeras hemsida att dom har lanserat nån ny teknik/kretslösning som ökar rörens livslängd och, om jag fattat det hela rätt, gör biasjusteringen "automatiskt", hela tiden. Fan tro't.
Själv tycker jag att det låter som en skitsmart grej men samtidigt är jag skeptisk när det blir för mycket teknik, då blir det ju också mer som kan fela.
Vad säger expertisen?
<i>"Our revolutionary INFINIUM Valve Life Multiplier technology is
like having your very own technician inside your amp constantly
monitoring and tweaking valve performance for the ultimate in tonal
integrity and reliability. This revolutionary circuit not only
optimizes the performance of each output tube, it dynamically
balances the drive between them to more evenly distribute the load.
With INFINIUM, your tubes last up to 20 times longer, saving you
substantial money over the lifespan of your amplifier. INFINIUM also
compensates for the effects of aging, automatically adjusting current
levels to keep your valves sounding as good as the day they were
installed.
If and when a valve does reach the end of its life, the system even
tells you which one to replace. All you need do is replace the faulty
valve and let INFINIUM take care of the rest for you. This all adds
up to more consistent sound quality and longer life for your valves.
Maintenance for valve amps has never been this easy!""]
EDIT: Hittade en länk där ni kan läsa lite mer: http://www.bugera-amps.com/EN/infinium.aspx
06 Apr 2011, 20:20
Ingent nytt på himlens port ..
denna teknik används sen 12år tillbaka i traynors yvc serie.
O fungerar ganska bra...
06 Apr 2011, 22:20
Users browsing this forum: tligen and 15 guests
