| Vad är detta för rör? https://ljudbojen.com/viewtopic.php?f=24&t=51592 |
Page 1 of 1 |
| Author: | Renegade [ 16 Jan 2011, 17:36 ] |
| Post subject: | Vad är detta för rör? |
Auktionen är snart slut men vad är det för rör? RCA 5R4GB är de benämnda. Först trodde jag att de var 5AR4 (GZ34) men 5R4or hittar jag inget om. http://www.tradera.com/RCA-5R4GB--par-a ... _125632938 /R <img src="http://i14.photobucket.com/albums/a308/torn_and_frayed/red-tonguesmaller.gif" border=0> "Art is the last thing I'm worried about when I'm writing a song. As far as I'm concerned, art is just short for 'Arthur'." - Keith Richards |
| Author: | wolfer [ 16 Jan 2011, 17:45 ] |
| Post subject: | |
http://www.radiomuseum.org/tubes/tube_5r4gb.html "Slightly more sag than a 5U4GB. Great option for amps that call for 5AR4/GZ34s where lower plate voltage, more sag/compression, and earlier breakup are desired." |
| Author: | rudmark [ 16 Jan 2011, 18:03 ] |
| Post subject: | |
Sneglat på dem lite grann själv....<i>Slightly more sag than a 5U4GB. Great option for amps that call for 5AR4/GZ34s where lower plate voltage, more sag/compression, and earlier breakup are desired."] <i>Tubes tested- RCA 5U4GB, RCA 5R4GB, RCA 5R4G, Sylvania 5R4GB, Sylvania 5R4GYB (brown base), Tung-Sol 5U4GB, National Union 5U4G, GE 5R4GYB with filament wire supports, GE 5U4GB, Raytheon 5R4GB, Raytheon 5U4GB (large tapered base) and a few off brand 5U4GBs. Results- The Sylvania 5R4GB smooth black plate were the best. Others produced a slight smearing across the audio. The GE 5U4GB & GE 5R4GYB with twin filament supports were worst with a fair amount of smearing. RCA 5U4GB, RCA 5R4G & RCA 5U4GB were not much better than the brittle sounding GE tubes. That Sylvania 5R4GB just fixed everything sonically. The sonic difference was like fine tuning a lot of top 20% of highest quality preamp tubes. That is one heck of a sonic difference here for a rectifier!!!! "] Ger du fan i att buda så får du köpa en av mig[:D] |
| Author: | VacuumVoodoo [ 16 Jan 2011, 18:59 ] |
| Post subject: | |
Intressanta rön om röret ifråga. Själv skulle jag inte sätta det i en förstärkare maed tanke på vad rekommenderade arbetsvillkor för röret är. T.ex. rekommenderas 4uF som 1:a glättningkondensator. Med de moderata spänningar vi har i förstärkarna (under 500V) är röret i princip oanvändbart. Ett 50W slutsteg vid 450V drar så där 150mA. Än sen då? frågar ni....Jo RIPPEL som blir en 100Hz sågtandsvåg med topp-topp amplitud på ca 380V. Det här röret är framtaget för användning i slutsteg som jobbar med sisådär nära 1000V anodspänning. Tar man 10x större glättningkondensator dvs 40uF så förkortas livslängden avsevärt. De påstådda ljudmässiga fördelar anser jag blir helt neutraliserade av den skada som kommer att drabba plånboken. Alex http://www.youtube.com/vacuumvoodoo |
| Author: | Renegade [ 16 Jan 2011, 19:29 ] |
| Post subject: | |
Tack för svaren. /R <img src="http://i14.photobucket.com/albums/a308/torn_and_frayed/red-tonguesmaller.gif" border=0> "Art is the last thing I'm worried about when I'm writing a song. As far as I'm concerned, art is just short for 'Arthur'." - Keith Richards |
