| Bad Cat schema ? https://ljudbojen.com/viewtopic.php?f=24&t=22802 |
Page 1 of 1 |
| Author: | gammelnalle [ 10 Jan 2009, 12:08 ] |
| Post subject: | Bad Cat schema ? |
Har frågat förr men inget bra svar då. De schemor som finns på schematic heaven passar inte in på de modeller jag sett på. Dels finns det en variant med effekomkoppling mellan OLIKA slutrör (EL84 resp EL34)och en där man kopplar bort/eller om 2 EL84... saxat på deras hemsida: HOT CAT 15 / 30 WATT Hi-Gain 2 Channel, Gain and Clean : Dual Speaker Outs Speaker Impedence Selector Control knobs include: Clean Volume, Gain, Edge, Level, Bass, Treble, Brilliance, and Gain Master Volume. The power section supports a continuous thick overdrive speaker power and a strong reserve of clean headroom. The 15 Watt using dual EL84’s, the 30 Watt dual EL34's. In contrast to other Class A models to date, as regards extraordinary sound possibilities, the Hot Cat runs appreciably ahead of the pack. TREM CAT : 30 WATT 1 Channel, 2 Input : Variable Tone Controls, Tremolo, Reverb, Hi-Lo Power, Speaker Impedence Switch, Speaker Phase Switch The all new Trem Cat model incorporates a stunning combination of both speed and depth controlled Tremolo and spring Reverb to deliver the widest range of sound possibilities available from Bad Cat. The Trem Cat control panel offers two inputs and: Volume, Tone, (EQ) Select, Bass, Treble, Speed, Depth, Cut, Master and Master On/Off. Power On/Off and the Standby toggles on the rear. Powered by 4xEL84’s for excellent clean headroom and significant reserve; the rear panel also includes a Hi/Lo switch for 15W attenuation. The sophisticated Pre-amp section harnesses unlimited sound shaping capability using a Pentode EF86 with a series of 12AX7’s for the interactive Tone, Tremolo and Reverb modules. Entirely based on Class A point to point circuitry, the Trem Cat is a gem of engineering design rendering it your best possible tool for creating a very broad range of truly satisfying sounds. Vore intressant och se hur man löst impedansanpassningen. b |
| Author: | d95err [ 10 Jan 2009, 20:21 ] |
| Post subject: | |
Är det verkligen switchning mellan EL34 och EL84? Jag ser inget i texten som direkt anger att det skulle vara dubbel uppsättning slutrör. Jag tycker det låter som att det helt enkelt finns två olika versioner av Hot Cat - en med EL84 och en med EL34. På Trem Cat med 4x EL84 är det väl inte svårare än att man switchar gallret för två av slutrören till jord? Erik R |
| Author: | gammelnalle [ 11 Jan 2009, 13:08 ] |
| Post subject: | |
kanske du har rätt... ägaren till den jag provade visste bara att den gick att "halvera".. Men får du den effekten om du triodkopplar 2 av rören??? b |
| Author: | d95err [ 11 Jan 2009, 15:11 ] |
| Post subject: | |
Jag tänkte på styrgallret, inte skärmgallret (otydligt uttryckt av mig). Jag måste dock erkänna att jag inte är säker på att det får den effekten. Ett enklare sätt är annars att koppla ifrån katoden på två av rören. Jag antar att det blir mismatch på impedansen då, men gissningsvis struntar de helt enkelt i det. Erik R |
