| Säljer en ESR, induktans, kapacitans mätare /Väck! https://ljudbojen.com/viewtopic.php?f=24&t=105225 |
Page 1 of 1 |
| Author: | rudmark [ 04 Oct 2015, 19:48 ] |
| Post subject: | Säljer en ESR, induktans, kapacitans mätare /Väck! |
Köpte en till och lär aldrig behöva två..... ![]() ![]() " * Add boot voltage detection function * Automatic detection of NPN and PNP transistors , N -channel and P-channel MOSFET, diodes ( including dual diode ) , thyristors , transistors, resistors and capacitors and other components , * Automatic test out the pin element and displayed on the LCD * Can be detected to determine the transistor emitter forward bias voltage of the transistor , MOSFET protection diode and the amplification factor of the base * Measure the gate threshold voltage and gate capacitance of the MOSFET * 1602 lcd display uses LCD (12864 LCD with backlight ) * High test speed , valid component test: 2 seconds ( except in the larger capacitor of large capacitance measurement also takes a long time , the measured time of one minute is normal ) * One button operation , power-on test , get a key . Mäter OK. * Power consumption off mode : less than 20 nA of * Auto power off function to avoid unnecessary waste , saving battery power , improved battery life." |
| Author: | busse [ 04 Oct 2015, 21:58 ] |
| Post subject: | Re: Säljer en ESR, induktans, kapacitans mätare |
Inte för jag riktigt hur den funkar och för 60 kr ink frakt köper jag den. Skicka PM om betalning. |
| Author: | rudmark [ 05 Oct 2015, 09:34 ] |
peterh fick den. |
| Author: | Michael [ 05 Oct 2015, 11:08 ] |
| Post subject: | Re: Säljer en ESR, induktans, kapacitans mätare /Väck! |
Här var man för långsam men var köpte du dem ifrån? Blev lite sugen. M |
| Author: | rudmark [ 05 Oct 2015, 12:47 ] |
aliexpress.com |
| Author: | Michael [ 06 Oct 2015, 07:26 ] |
Tack Får se om det blir en order därifrån. |
| Author: | busse [ 06 Oct 2015, 08:25 ] |
Är det lönt att sambeställa eller blir det dyrare med frakten inom Sverige? Jag är i alla fall intresserad av en sån där mätare. |
| Author: | rudmark [ 06 Oct 2015, 10:31 ] |
busse wrote: Är det lönt att sambeställa eller blir det dyrare med frakten inom Sverige? Jag är i alla fall intresserad av en sån där mätare. Nästan allt därifrån är "free shipment". Så sambeställning verkar overkill..... |
| Author: | awe [ 10 Oct 2015, 01:49 ] |
Första bilden; 2358 uF??? |
