| VOX Night Train 50 Rörtopp säljes/bytes mot 100w topp/kombo https://ljudbojen.com/viewtopic.php?f=10&t=108235 |
Page 1 of 1 |
| Author: | lidfors [ 17 Mar 2016, 00:48 ] |
| Post subject: | VOX Night Train 50 Rörtopp säljes/bytes mot 100w topp/kombo |
Vox Nighttrain 50 Topp Helrör Lunchbox, inkl fotpedal. Byten kan vara av intresse men endast mot en likvärdig 100w topp(kombo kan funka) Bytesvärde 5000-5500 kr Men jag är öppen för förslag! Frakt Bussgods i originalemballage http://www.sweetwater.com/store/detail/NightTrain50 Night Train 50 Tube Guitar Amplifier Head description: The VOX Night Train 50 Tube Amplifier Head is a powerful, all-tube, Class AB, 50 Watt head that offers two channels for traditional and high-gain sounds VOX Night Train 50 Overview The Night Train 50 Head's preamp stage is equipped with four 12AX7 vacuum tubes; two EL34 pentode power tubes. This unique tube complement allows the Night Train 50 to capture the traditional VOX chime sound, as well as creating a powerful high-gain sound that will revolutionize your ideas about VOX amps. The Night Train 50 features a two-channel design. The BRIGHT channel provides the inimitable VOX chime sound; the high-gain GIRTH channel utilizes an extra pre-amp tube for more crunch. Each channel offers Bass, Middle, Treble, and Gain controls for sculpting your sound. The BRIGHT channel provides a THICK mode that bypasses the EQ to boost the gain and make the sound even thicker. The Master section includes the traditional Master Volume and the VOX Tone Cut control, plus a new TIGHT switch. The TIGHT mode applies to both channels; it attenuates the low-frequency range to tighten the low end , providing even more sonic possibilities. The VOX Night Train 50 Tube Amplifier Head main features: All-tube, two channel head featuring Class AB amplifier construction Stylish design with eye-catching mirror finish 12AX7 (x4) preamp tubes; EL34 (x2) power stage tubes BRIGHT channel provides the traditional VOX chime; plus a THICK switch which bypasses the EQ for more gain GIRTH channel delivers an energetic powerful high-gain tone Master TIGHT switch cuts the low end to tighten the overall sound FX loop with tone-saving true bypass Optional VFS2A footswitch; Switch between channels or turn the BRIGHT channel’s THICK mode on and off |
