https://ljudbojen.com/
Chandler Tone X. (Mid Boost Preamp.)
https://ljudbojen.com/viewtopic.php?f=1&t=17765
Author:  rolwoody [ 01 Aug 2008, 08:50 ]
Post subject:  Chandler Tone X. (Mid Boost Preamp.)
<font color="red">Ser ut ungefär som på bilden. (Min är dock en lite äldre variant.)</font id="red">
<u><b>Chandler skriver själva:</b></u>
<b>" </b> The Chandler Tone X push-pull pot is like a Wah pedal at your fingertips; a mid boost preamp that fits inside most guitars without modification. It boosts output by 16db and allows guitarists to sweep the midrange peak from a low growl to piercing highs, offering great control over melodic, singing feedback. Powered by a single 9V battery and made in USA, the Tone X is used extensively by Joe Perry of Aerosmith and is included as a standard feature in Gibson's extra-cool Joe Perry signature model Les Paul guitar. <b>"</b>
<b>Chandler Tone-X Guitar Preamp Features:</b>
• Requires no routing for most guitars.
• Push/pull pot to boost output by 16dB.
• Allows player to sweep the midrange peak from a low growl to piercing highs.
• Effect is like having a wah wah at your fingertips.
• Powered by a 9-volt battery.
• Circuit is completely bypassed until you blast off with searing controlled feedback.
Enkel att montera, så länge potentiometer med kort och batteri får plats. [:D]
Pris: 250:-
