| diverse https://ljudbojen.com/viewtopic.php?f=1&t=15076 |
Page 1 of 1 |
| Author: | Cadillac [ 05 Apr 2008, 18:44 ] |
| Post subject: | diverse |
Korg ampworks. 500:- Gammal Marshall Guv'nor made in UK saknar batterilucka 500:- Ny Floyd Rose översadel krom R4 150:- MXR EvH signature Flanger 1100:- ![]() Frakter tillkommer, bättre bilder ordnas om så önskas.. |
| Author: | javelin70 [ 06 Apr 2008, 15:37 ] |
| Post subject: | |
marcusss wrote: har KNE nån websida? googlade men hittade inget http://kneguitars.com/ Micke |
| Author: | Honeyburst [ 06 Apr 2008, 17:00 ] |
| Post subject: | |
Här: http://kneguitars.com/kit_bod.php
| Author: | Cadillac [ 13 Apr 2008, 19:18 ] |
| Post subject: | |
Bump! |
| Author: | Cadillac [ 28 Apr 2008, 08:29 ] |
| Post subject: | |
bump |
| Author: | cruiser [ 01 May 2008, 10:40 ] |
| Post subject: | |
Jag vill ha det svarta plektrumskyddet med de svarta kåporna! |
| Author: | Cadillac [ 01 May 2008, 10:54 ] |
| Post subject: | |
cruiser wrote: Jag vill ha det svarta plektrumskyddet med de svarta kåporna! OK, lägger det åt sidan |
| Author: | greppet [ 01 May 2008, 11:47 ] |
| Post subject: | |
Tjena John Du har mail..jag köper Sheptone setet. mvh Pelle " Greppet" Lindberg http://www.pellelindberg.com "Blues From The South" |
| Author: | Cadillac [ 01 May 2008, 11:48 ] |
| Post subject: | |
greppet wrote: Tjena John Du har mail..jag köper Sheptone setet. mvh Pelle " Greppet" Lindberg http://www.pellelindberg.com "Blues From The South" Mycket klokt Pelle, mycket bra mickar[:)] |
| Author: | greppet [ 01 May 2008, 11:57 ] |
| Post subject: | |
Cadillac wrote: greppet wrote: Tjena John Du har mail..jag köper Sheptone setet. mvh Pelle " Greppet" Lindberg http://www.pellelindberg.com "Blues From The South" Mycket klokt Pelle, mycket bra mickar[:)] Dom kommer att låta kanon ihop med Boogie bodies kroppen jag köpte av dig för ett par år sen... /Pelle mvh Pelle " Greppet" Lindberg http://www.pellelindberg.com "Blues From The South" |
| Author: | Cadillac [ 01 May 2008, 12:06 ] |
| Post subject: | |
Quote: Dom kommer att låta kanon ihop med Boogie bodies kroppen jag köpte av dig för ett par år sen... /Pelle Det är jag övertygad om, alkropp tilsammans med dom här är kalas. |
| Author: | Puttarn [ 01 May 2008, 15:09 ] |
| Post subject: | |
Du har mail |
| Author: | Stelin [ 07 May 2008, 23:19 ] |
| Post subject: | |
Hur ser egentligen kroppen ut under plektrumskyddet? Visst finns en bild på KnE, men jag får det inte att gå ihop med den snedställda sc:n. [:)] |
| Author: | Cadillac [ 08 May 2008, 00:53 ] |
| Post subject: | |
Stelin wrote: Hur ser egentligen kroppen ut under plektrumskyddet? Visst finns en bild på KnE, men jag får det inte att gå ihop med den snedställda sc:n. [:)] Det är riktigt, det är lite mer urfräst för att få plats med den snedställda micken. Kan fixa en bild senare om intresse finns, men är inte hemma på några dagar. |
| Author: | Cadillac [ 08 May 2008, 17:39 ] |
| Post subject: | |
marcusss wrote: Cadillac wrote: Alkropp från Kne modell "The Frank" Är det cellulosalack? Vad menar du med att du skippade och körde med vanligt plektrumskydd, är den backroutad möjligtvis? Nej, det är 2-komp billack. "The Frank" står för att den är fräst som EvH's Frankenstrat och han hade ett söndersågat plektrumskydd på sin och mickarna fastskruvade direkt i trät. Alltså inte backrouted |
| Author: | Stelin [ 08 May 2008, 19:36 ] |
| Post subject: | |
Cadillac wrote: Stelin wrote: Hur ser egentligen kroppen ut under plektrumskyddet? Visst finns en bild på KnE, men jag får det inte att gå ihop med den snedställda sc:n. [:)] Det är riktigt, det är lite mer urfräst för att få plats med den snedställda micken. Kan fixa en bild senare om intresse finns, men är inte hemma på några dagar. Hmm, tja...Bild var inte hela världen. Undrar mest om en humbucker skulle få plats...[:)] |
| Author: | Cadillac [ 08 May 2008, 21:07 ] |
| Post subject: | |
Quote: Undrar mest om en humbucker skulle få plats... Inte utan mer fräsning. |
| Author: | FenderBender [ 17 May 2008, 21:10 ] |
| Post subject: | |
Vilken profil har halsen? Jag jagar en U-profil, eller fet C-profil. Mvh / Janne [:o)] <font color="green">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="green"> |
| Author: | Cadillac [ 17 May 2008, 21:13 ] |
| Post subject: | |
FenderBender wrote: Vilken profil har halsen? Jag jagar en U-profil, eller fet C-profil. Mvh / Janne [:o)] <font color="green">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="green"> Den har det du söker, fet U skulle jag kalla det, 25mm tjock hela vägen. |
| Author: | FenderBender [ 17 May 2008, 23:09 ] |
| Post subject: | |
Du har mail [:D] [:o)] <font color="green">If you can bend it you can mend it, if you can't mend it don't bend it - just make shure it's a Fender, Bender!</font id="green"> |
| Author: | cruiser [ 07 Jul 2008, 00:16 ] |
| Post subject: | |
Bjuder på en bump så den inte åker ur... |
| Author: | bastard [ 07 Jul 2008, 06:41 ] |
| Post subject: | |
Hur väl funkar en Korg ampworks? http://www.infernalvengeance.com |
