https://ljudbojen.com/
Defekt Laney GH 100L SÅLD !!!!!
https://ljudbojen.com/viewtopic.php?f=1&t=13795
Author:  sch [ 11 Feb 2008, 20:47 ]
Post subject:  Defekt Laney GH 100L SÅLD !!!!!
Jag har en snygg Laney GH 100L top, som bara
har ståt i ett studie. Den tänder och ljuser,
men säjar ingenting....[}:)].....SÅLD !!!!!
The GH100L is a single channel master volume style head with footswitchable gain. It is capable of a huge variety of sounds, from sparkling clean through powerful crunch to full on monster tones and everything in between. If tone capable of turning people's heads at 100 yards is what you're after - look no further. As well as astounding tone these heads offer a valve-coupled effects loop and link jacks for slaving several heads together. The GH100L features an ECC83 equipped preamp and EL34 output section, easily switchable for 5881's if so desired. The GH100L is designed to be used with the GS412IA and GS412IS cabinets - to enhance the amplifiers huge tonal range and produce stunning tone at any volume.
Features
Power RMS: 100 Watts
Inputs HI & LO Jacks
Channels: 1: with footswitchable Gain
Equalisation: Bass, Middle, Treble
Master Presence Control
Switchable Resonance
Preamp Valves: Premium ECC83
Output Valves: Premium EL34
Switchable valve bias (5881 / EL34)
Class A/B
Link Jack (Line Level Slave)
Footswitch: FS1 (Not included)
Speaker connections: Connections for 1 x 16 ohm, 2 x 16 ohm, 1 x 8 Ohm, 2 x 8 ohm
FX Loops (Switchable Insert / Side Chain) with return level
Weight: 22.5 kg
Dimensions (mm) 265 x 680 x 255
Jag spelar inte 100 watt, så jag bytter gärna
med någon, som är mera kunnig på rör än jag....
Följande kan fresta:
En elektrisk 12'or
En liten rörcombo av bra märke
Telor och Strator
En superduper compressor (Keeley eller liknande)
VG 8 eller VG 88
eller.....??????? (ingen hårdrocksguror !!!)
Nypris på toppen är 839.- Euro !!
Author:  sch [ 14 Feb 2008, 16:51 ]
Post subject:
Några bud ??? Kom friskt till.....jag blir inte arg...!!
Author:  sch [ 18 Feb 2008, 23:45 ]
Post subject:
Eller säljas för 1200.- avhäntat
i Helsingör, där man också kann
köpa gott öl !!![:p]
Author:  rolwoody [ 21 Feb 2008, 00:54 ]
Post subject:
Du har mail via profilen...
Author:  sch [ 21 Feb 2008, 01:08 ]
Post subject:
Inte än....!!!! ?[:D]
Author:  rolwoody [ 21 Feb 2008, 08:03 ]
Post subject:
Mail skickat på nytt.
Author:  svaj [ 21 Feb 2008, 23:40 ]
Post subject:
mail från helsingborg
bobby saves!
Author:  rolwoody [ 25 Feb 2008, 07:57 ]
Post subject:
Hej igen.
Får du mina mail?
Jag får inget tillbaka.
Author:  rolwoody [ 25 Feb 2008, 15:56 ]
Post subject:
Tack så hemskt mycket för att du svarat... [xx(]
