View unanswered posts | View active topics It is currently 13 Oct 2026, 23:57
John Lennon 1965 Casino
Post John Lennon 1965 Casino
Tänker sälja min Epiphone Casino. Det är en John Lennon 1965 reissue, byggd av Gibson's custom shop i Nashville.
Mint cond. Fantastiskt bra instrument som låter kanon. Original case och alla tags finns.
25 papp. Inga byten. Guran finns i Stockholm.
Maila om intresse finns.
Specifications
Original Body Shape - Based upon Mid - '60's Kalamazoo, Michigan tooling specs
Body Materials - 5-layer (Maple/Birch/Maple/Birch/Maple)
Top Contour Bracing - Spruce with original relief-cut spacing and depth
One-piece Mahogany Neck with 14 degree neck grain orientation
Rosewood Fingerboard with original 0.062" thick pearloid parallelogram fret markers
Stamped with John's original serial number on the back of the headstock (#328393)
Original Elliptical Neck Shape
Neck Binding over fret ends
Scale Length - 24.75"
Original "Corian" nut material
Headstock Angle - 17 degrees
Nickel-plated, Dog-Earred P-90 Pickup Cover with Original String Spacing
Nickel plated "Gibson-Factory" Hardware
"Gibson-Factory" Electronics
Dove-Tail Neck-Joint at the 16th fret
Switchcraft toggle switch with original toggle switch washer
Original style "Push-in" machine head bushings
ABR Bridge with nylon saddles
Vintage style case with shroud
Finish:
Vintage Sunburst Color with nitro-cellulose lacquer finish over white body binding - hand buffed
Pickguard:
3-ply (W/B/W) pickguard with original shape and foil "E" mark
Tuners:
Nickel plated Gotoh "Kluson-style" machine heads
11 Jun 2012, 15:23
Users browsing this forum: Google [Bot] and 27 guests
