View unanswered posts | View active topics It is currently 20 Sep 2026, 09:06
ZOOM GFX-3 ----SÅLD
Post ZOOM GFX-3 ----SÅLD
Köpte den för ett speciellt projekt, men är ju ingen multi-snubbe så den får gå igen till REA-priset 800 bagis
löjligt lättkranad och stadig plåtlåda gör detta till en perfekt live-burk. Funkar perfa till hemmastudion också. Lajna direkt in i ljudkortet eller PAt. Bra högtalarsimulator ger dig allt från Fendercombo till gigantisk Marshall-stack. Riktigt bra distljud och en massa annat kul också. Expressionpedalen dubblar som volympedal. Mycket användbart indeed.
Inbyggd stämmare och en jäkla massa presets plus massor av utrymme för egna presets också
Nyskick!
<img src="http://www.jam.se/images/Zoomgfx3.jpg" border=0>
<img src="http://smilies.f-o-o-l.de/crazy.gif" border=0>The beat goes on and I´m so wrong
Edited by - Joshunznera on 17 January 2006 20:02:27
Edited by - Joshunznera on 17 January 2006 20:11:50
Edited by - Joshunznera on 18 January 2006 08:25:39
16 Jan 2006, 07:29
lite mumbo jumbo:
VAMS (Variable Architecture Modeling System) for incredible distortion
Analog distortion circuitry creates the muscle, while digital filtering finds the "sweet spot". This hybrid modeling technology, VAMS, developed by ZOOM, combines the best of the analog and digital worlds.
10 amp sounds, and 10 distortion effects
10 guitar amp sounds that are well-known standards around the world are at your fingertips, along with 10 different types of effects. Enjoy the realistic drive sound of various tube amps, from vintage combo to modern high gain. Choose from two variations (STANDARD and CLASSIC), to get a 60s and 70s sound. Or use the acoustic simulator that makes an electric guitar sound like an acoustic.
GUITAR AMP Models
FDR Blues / FDR Clean / MS Old / MS Drive / BG Old
BG Drive / VX Crunch / Jazz C / MP-1 / PV Drive
STOMP BOX Models
ZOOM 9002 / ZOOM PWR / Vintage OD / ZOOM PD-01 / Vintage Dist
Hyper Dist / Wild Fuzz / ZOOM UF-01 / Metal Z / Metal 7th
Foot switches give direct access to three patches
The GFX-3 has three pedals for direct access to three of your favorite effect patches. Ideal for playing live. They also let you quickly scroll through banks of effects.
Intuitive user interface
The panel layout is designed to show effect parameters as a matrix that lets you see at a glance what is happening. The combination of module keys and parameter keys gives access to all edit parameters. The VALUE dial has that smooth analog feel, while parameter values are clearly shown on the digital readout. Perform precise editing every time.
7 effect modules and 50 effects
The GFX-3 offers 50 effects in various categories including dynamics, drive, modulation, and ambience. It's like having seven stomp boxes all in one place. All the regular effects for guitar are there, plus some unconventional ones such as SFX and REVERSE DELAY. Each effect type has four parameters, letting you adjust the delay time in BPM, change the wah connection point to before the drive module, or shape the sound in many other ways.
60 preset patches duplicate the sound of famous artists
The impressive array of preset patches covers the sound of musical greats in many genres. Standard Rock 'n Roll, Jazz, Blues, Funk, Alternative, you name it: the GFX-3 has it. Patches for vintage effects and representative amp modeling settings are also available. Or create your very own patches and store them in the 60 slots of the user memory.
Control effects with expression pedal in real time
The built-in pedal is a great tool for any stage performance. Not only can you adjust volume, wah, or pitch, you also have control over aspects such as distortion effect gain, modulation speed, or reverb mix. The dedicated pedal assign key lets you quickly choose the effect to control.
Seven amp cabinet simulator settings
The amp cabinet simulator is great for producing speaker sound from a guitar with line connection. This is useful when working with headphones or recording directly onto a multi-track machine. Choose from seven settings including Combo, Bright Combo, and Stack.
Energizer produces powerful sound even from a small amp
The Energizer effect continually enhances the mid and high range frequencies and ensures a tight low end. You can use it to make a guitar stand out in band setting, or produce powerful, dynamic sounds from even a small guitar amp.
ZNR (Zoom Noise Reduction)
ZNR was developed by Zoom with the specific aim of optimizing guitar sound. Noise in playing pauses is efficiently removed while keeping any impact on the original sound to a minimum. This assures a natural sounding release also after a long sustain.
Integrated auto chromatic tuner
High-brightness LED indicators allow easy tuning also on a dark stage. The inventive Zoom method clearly shows pitch shifts by the rotation speed of the indicators, for quick and intuitive fine tuning. The mute function is convenient for use on stage without having to worry about the sound.
Metal chassis designed for use on stage
Most effects pedals these days are made of plastic. Not this one. The metal chassis of the GFX-3 can withstand the rigors of the road, use on stage or in the rehearsal studio, as well as during frequent transport. Stability is excellent, which is important when connecting cables and using the pedal. Jacks are mounted to the chassis with retaining nuts, so that the internal circuitry is protected even if a jack should be accidentally subjected to excessive force.
11 hours continuous operation on one set of AA batteries
The low power consumption design allows the GFX-3 to operate continuously for 11 hours on one set of four IEC R6 (size AA) alkaline batteries. There's no more need to worry about running out of juice during a live performance. For extended studio work or rehearsals, the separately available AC adaptor (AD-0006) can help reduce running costs.
EFFECT LIST
COMP Module
01. COMPRESSOR
02. ISOLATOR
DRIVE Module
03. FDR BLUES
04. FDR CLEAN
05. MS OLD
06. MS DRIVE
07. BG OLD
08. BG DRIVE
09. VX CRUNCH
10. JAZZ C
11. MP-1
12. PV DRIVE
13. ZOOM 9002
14. ZOOM PWR
15. VINTAGE OD
16. ZOOM PD-01
17. VINTAGE DIST
18. HYPER DIST
19. WILD FUZZ
20. ZOOM UF-01
21. METAL Z
22. METAL 7th
23. CLASSIC ACOUSTIC SIM
24. STANDARD ACOUSTIC SIM
EQUALIZER Module
25. 4 BAND EQUALIZER
ZNR Module
26. ZNR
27. D GATE
CABINET Module
28. CABINET SIMULATOR
MODULATION Module
29. CHORUS
30. FLANGER
31. PHASER
32. WAH
33. TREMOLO / AUTO PAN
34. VIBERATO
35. PITCH SHIFT
36. SFX
37. SLOW-ATTACK
38. RING MODULATOR
39. PEDAL PITCH
DELAY REVERB Module
40. HALL REVERB
41. ROOM REVERB
42. SPRING REVERB
43. MONO DELAY
44. PING PONG DELAY
45. ECHO
46. PING-PONG ECHO
47. REVERSE DELAY
48. DELAY + HALL
49. DELAY + ROOM
50. DELAY + SPRING
Edited by - Joshunznera on 17 January 2006 20:13:24
Edited by - Joshunznera on 17 January 2006 20:16:02
17 Jan 2006, 21:12
Josh har mail
18 Jan 2006, 00:40
