View unanswered posts | View active topics It is currently 16 Apr 2024, 17:29
OKKO Diablo +
Post OKKO Diablo +
Fantastisk overdrive pedal- Micke Nord spelade på den här tillsammans med en olsson-stärk på fuzz mässan - jag blev såld!! trots det har jag nu slutat använda den, så den får gå vidare ...
1500 :-
Quote:
The Diablo is a versatile low to medium gain overdrive with an
exceptionally dynamic response. It preserves the character of your instruments and is very sensitive to your playing technique.
Thanks to the effective and musical controls, the Diablo works equally well with
any kind of guitar, amp or playing style. People use it for so many different sounds,
you would hardly believe that they use the same pedal.
"I'm gonna put a curse on you and all your kids will be born completely naked. " J.Hendrix
01 Feb 2018, 17:01
Post Re: OKKO Diablo +
Finns OKKO pedalen kvar?
Hur är skicket på den?
04 Feb 2018, 20:14
den finns kvar och skicket är perfekt!
04 Feb 2018, 20:34
diablo /hinhåle ...
13 May 2018, 21:30
