View unanswered posts | View active topics It is currently 21 Sep 2026, 06:58
Virus
Post Virus
Har fått ett mail "info" där det står "Warning you may have a virus" och att viruset ska heta "W32/Lentin.F@mm".
Jag har även fått massa mail från "postmaster@spa.se" där det står "MDaemon Warning - Virus Found".
Det konstiga är att jag har kört Norton scan och det hittar inget virus.
Är det nåt man ska ta på allvar?
10 Apr 2003, 20:52
hittade den här infon:
W32/Lentin.F@mm is a mass-mailing worm that arrives as an email with a randomly chosen subject and message body. The attachment will have a .bat, .pif, or .scr file extension. Possible message bodies include:
Ur My Best Friend!!
No Configuration is availabile Now
Config
madd
U r so cute today #!#!
True Love never ends
I like U very Much!!!
The worm will save a file with a random 4 character filename to the hard drive with the following text strings:
iNDian sNakes pResents yAha.e
iNDian hACkers, Vxers cOme & wORk wITh uS & f!@# tHE GFORCE-pAK sites
by
sNAkeeYes, cOBra
W32/Lentin.F@mm will use its own SMTP engine to send a copy of itself to all the email addresses it has collected. It will also try to disable many antivirus packages and personal firewalls.
Detection:
Command Antivirus version 4.58.3 with definition files dated 06/21/02 will detect this worm.
Manual Removal Instructions:
Because W32/Lentin.F@mm will interfere with the launching of an .exe file, you have to copy regedit.exe to regedit.com before launching it. Be sure to make a backup of the registry before attempting to make any edits.
Shutdown and restart the computer in safe mode.
Run Regedit.com and modify the following key:
HKEY_CLASSES_ROOT\exefile\shell\open\command
This value should be changed to "%1" %*
Empty the recycle bin.
Shutdown and restart the computer.
Empty the recycle bin again.
Run CSAV and delete all infected files.
http://kickass.at/pungbuffel<img src="http://www.linkoping.bonet.se/pungbuffel/scrotum.gif" border=0>
10 Apr 2003, 21:34
Ur My Best Friend!!
Config
madd
by
sNAkeeYes, cOBra
Detection:
Tackar!
Jag ska ta och kolla upp det närmare.
10 Apr 2003, 22:28
Här finns ett verktyg som tar bort det.
http://www.pandasoftware.com/library/W32LentinE_en.htm
//Daniel
10 Apr 2003, 22:46
//Daniel
Den hittar ingenting.
Verkar vara nåt fejkvirus eller nåt...
11 Apr 2003, 14:48
Jag känner inte till hur just det där viruset gör, men ibland fejkar virusen avsändaradress. Detta innebär att ett virus kommit till nån person, vars virusprogram tror att du skickat det. Då skickar det varningen tillbaka till dig.
Det <b>behöver</b> alltså inte vara ett virus hos dig bara för att du får såna mail. Däremot är det alltid en bra ide att ha en viruskollare igång.
11 Apr 2003, 16:28
Users browsing this forum: Majestic-12 [Bot] and 22 guests
