View unanswered posts | View active topics It is currently 26 Sep 2026, 13:45
Inte Den Heliga Skrift precis men...
Post Inte Den Heliga Skrift precis men...
...betydligt roligare.
http://www.spinaltapfan.com/scripts/tist411.txt
Nigel:
The sustain...listen to it...
Marty:
I'm not hearing anything.
Nigel:
You would, though, if it were playing, because it really
... it's famous for its sustain...I mean, you could, just hold it....
Marty:
Well I mean so you don't....
Nigel:
Aaaaaaaaaaaaaa.... You could go and have a bite an'...aaaaaaaaa...you'd still be hearin' that one.
Could you hold this a sec'?
16 Aug 2005, 11:50
Nigel: This is a top to a, you know, what we use on stage,
but it's very...very special because if you can see...
Marty: Yeah...
Nigel: ...the numbers all go to eleven. Look...right across the
board.
Marty: Ahh...oh, I see....
Nigel: Eleven...eleven...eleven....
Marty: ..and most of these amps go up to ten....
Nigel: Exactly.
Marty: Does that mean it's...louder? Is it any louder?
Nigel: Well, it's one louder, isn't it? It's not ten. You see,
most...most blokes, you know, will be playing at ten.
You're on ten here...all the way up...all the way up....
Marty: Yeah....
Nigel: ...all the way up. You're on ten on your guitar...where
can you go from there? Where?
Marty: I don't know....
Nigel: Nowhere. Exactly. What we do is if we need that extra..
push over the cliff...you know what we do?
Marty: Put it up to eleven.
Nigel: Eleven. Exactly. One louder.
Marty: Why don't you just make ten louder and make ten be the
top... number... and make that a little louder?
Nigel: These go to eleven.
Edited by - knedy on 16 August 2005 12:12:30
16 Aug 2005, 12:11
